Sylvania LC-26SS1 Power Supply issues
  • Shinju
    • Mar 2014
    • 1239
    Hello!
    I recently got a Sylvania 26" LCD panel for cheap as it did not turn on.
    I pulled the back off and noticed the 125v 4a fuse was toasted, so I put another fuse (5a I had for a 12v car stereo) in and plugged in the panel and tried to turn it on and no luck. The new fuse did not blow but the panel did nothing no turn on or red power light ect.
    The 2 1000uf caps look to the eye good but I am going to replace them anyway as well as the 2200uf cap behind the transformer cased in yellow.
    What would cause the fuse to blow in the first place, bad caps or a series of other failed components?
    Here are the photos of the entire spread of the panel, not much to it so this is all that was able to be photographed.
    Thanks in advance! I am getting a new DMM today as my old one is failing on me.
    -j
  • Shinju
    • Mar 2014
    • 1239
    Re: Sylvania LC-26SS1 Power Supply issues
    Replaced all of the 1000uf and 2200uf caps and got a proper fuse and still nothing, I am getting voltage through out the power supply.
    • capkid
      • Oct 2010
      • 1339
      The Sylvania LCDs I've read about have had diode failures in the power supply.
      LG Plasma Mal-Discharge Correction Service
      • Shinju
        • Mar 2014
        • 1239
        Thanks!
        The board has 2 toasted transformers and a few other parts that I discovered. The cost of the parts exceeded the price i found for a refurbished power supply that I had found on a site. I ended up getting it and the tv fired right up and now is used in my friends mothers house .
        • Babbar
          by Babbar
          04-12-2024, 01:12 AM
          by sam_sam_sam
          03-31-2024, 02:12 PM
        • vletr
          Edac/Drobo Power Supply Fuse
          by vletr
          Looking for next steps on troubleshooting for an external power supply made by EDAC, model EA11011H-120. The power supply was dropped onto a tile floor and initially and briefly worked but the led power indicator light faded out and the power supply showed no signs of life since.
          In disassembly, I found that the large capacitor had leaked and was reading open when measured. The fuse nearest to the AC in had also blown, with no continuity. I ordered a new capacitor and fuse and replaced both, but on power-up with no load the fuse immediately blew.
          05-25-2023, 07:15 AM
          Used a Ring tester to troubleshoot a switching power supply that has a blowed fuse
          by sam_sam_sam
          I found this switching power which has a blowed fuse checked diodes which were still good out of circuit checked main filtering capacitor with an ESR meter 220uf@450 volts 0.15 value which to me seem bad but maybe not but without these items not in the circuit because I have about 8 ohm on the output of the capacitors so I removed the switching power supply transformer and checked it with a ring tester and all but one winding showed good all others either showed two red lights or no lights on and one winding had all lights on which was the only one that was good
          One other check that...
          08-03-2021, 06:41 PM
