Vizio E420VL problem
  • CraigR
    • Dec 2013
    • 976
    I have a Vizio E420VL and when plugged in the logo is orange and push the power button and logo turns white but that's it. Checked the power board visually and no swollen caps or signs of anything getting hot. On the underside all solder joints look good under lighted magnification. I have checked the connection and seem to have all the correct voltages at the plug. I have read on this forum before posting this about a possible EEProm problem with these main boards so was hoping the experts would chime in and give me their opinion on this or if any further testing is required.
  • mu2
    • Oct 2009
    • 217
    Re: Vizio E420VL problem
    Craig,
    I wish I could help with an exact solution but I have the same set and same problem.
    I bought the programmed eeprom on e-bay and it didn't fix the issue. After I replaced the chip I noticed a chip on the main board getting very hot. It is P13HDMI245-AZLE and as I recall it was near the hdmi connectors. I think I missed it in my haste.
    You said that nothing was getting hot - but just double check this chip before you order the eeprom.
    Mouser has the hdmi chip in stock but I haven't changed it yet.
    It is possible that my set has multiple problems including the hdmi chip and eeprom.
    Good luck.
    Mike
    • CraigR
      • Dec 2013
      • 976
      Looks ok to me right now. But thanks for the info.
      • ecking767
        • Oct 2009
        • 492
        Question, when you power up your TV, can you power it off after being on for at least 30 second by press the power button?
        • CraigR
          • Dec 2013
          • 976
          Logo does go back to orange after powering off.
          • ecking767
            • Oct 2009
            • 492
            that tell me it may not be an EEPROM problem, can you correct a signal to the TV, or do you know the last known input that was being used?
            I will try to see if there is any sound by connecting to the HDMI ports using a source like PS3, Direct TV or DVD player
            or try the flash light test to the screen to see if any picture it present. like the menu once press the button?
            • CraigR
              • Dec 2013
              • 976
              not sure what you mean by correct a signal to the tv and I have no idea what it was set on last but I will try hooking up a video source and see it anything happens.
              • CraigR
                • Dec 2013
                • 976
                Ok I hooked a dvd player to it then cycled through the inputs and I DO have sound. I put a mag light up to the screen all over and can't see any video however.
                • ecking767
                  • Oct 2009
                  • 492
                  okay that good news, your main board is working. if you have a volt meter you will need to measure the "BL_ON" on the power supply connector.
                  • CraigR
                    • Dec 2013
                    • 976
                    There is nothing marked "BL_ON" but I do have one marked "OFF_ON" and that has 3.36V but I also have one marked "LAMP" and that has no voltage.
                    • ecking767
                      • Oct 2009
                      • 492
                      its seen to be your power supply inverter board that is not working. troubleshooting down to component will be complicated for me. I will replace the power supply & inverter board.
                      • CraigR
                        • Dec 2013
                        • 976
                        Even though no image?? I need to repair this one so hopefully one of the Pro's will give me some advice but thanks.
                        • ecking767
                          • Oct 2009
                          • 492
                          yes, to sum up, your TV power off/on, you have sound, unable to see picture because of no back-light, and BL_ON voltage is present.
                          measure the connection label "dim" on the power supply.
                          • CraigR
                            • Dec 2013
                            • 976
                            I think I should be able to see video with a strong flashlight even though no backlight.
                            • ecking767
                              • Oct 2009
                              • 492
                              I guess but not always an image can be seen on the screen using a flash light,depending on the room lighting and picture on the screen. or you could have multiple problems.
                              one other thing you can do is disconnect the two LCD screen cable and then power up the TV.
                              If you have voltage on "on/off" and "dim" pins , then your main board isn't the problem dealing with the no back light issue
                              • CraigR
                                • Dec 2013
                                • 976
                                From the Tcon board? and sorry what do you mean by "dim" pins?
                                • ecking767
                                  • Oct 2009
                                  • 492
                                  carefully disconnect the two flat cable from the main board,then power up the TV, too see if any changes come about.
                                  the "dim" on the power supply connector where you measure the "on/off" voltage.
                                  • CraigR
                                    • Dec 2013
                                    • 976
                                    with those 2 disconnected I still have 3.2V at the ON_OFF pin
                                    • ecking767
                                      • Oct 2009
                                      • 492
                                      what about the pin lable "DIM"? measure the voltage
                                      • CraigR
                                        • Dec 2013
                                        • 976
                                        oops, .78v same as when they are connected.
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • rajbot
                                          No Power problem with Vizio E60-E3
                                          by rajbot
                                          Hi all:
                                          I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
                                          I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
                                          On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
                                          03-22-2023, 08:09 AM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • MICHAEL_2013
                                          Change Logo Aptio Setup Utility 2021 (ROM Layout mismatch detected) Problem
                                          by MICHAEL_2013
                                          Good afternoon, Lords of great wisdom. My problem is the following: I bought a Chinese laptop with GN117_MB_V31-T board. (Aptio Setup Utility 2021) (There is no info for that board). And I want to change the logo of the bios. I have used Aptio_V Afuwin to do the bios Backup, then I change the logo with AMI ChangeLogo Tool v5.0.0.2 and everything seems perfect. But when you restart the new logo appears ok. But it automatically enters the bios, appearing a new option RECOVERY, ROM LAYOUT MISMATCH DETECTED - PARTIAL UPDATE IS NOT ALLOWED. If I give ESC it enters windows without problem but always...
                                          06-28-2021, 03:12 PM
