evesham v32eccb no power
  • snipersquad100
    • Nov 2013
    • 297
    Re: evesham v32eccb no power
    And yet china copy everything else lol
      Very limited copyright enforcement in China, too much corruption. That business employs people from the city I'm mayor of/judge of/have friends of? That company is paying me? Dismiss the lawsuit. etc.
      • Keshenatech1
        • Apr 2018
        • 149
        Did anyone ever find a schematic or a parts list? I'm working on one that has an open D9. It's a surface mount diode near IC 5. The body style looks more like a resistor than a diode, totally flat but has the white cathode stripe on it. Not sure if it's a regular diode, shottky, or a zener.
          This is old thread, please attach good clear high res straight shots pictures of the whole top and bottom side of your board, and closed up pictures around the part in question.
          • Keshenatech1
            • Apr 2018
            • 149
            Does anyone have a schematic, BOM, parts list, etc. for these? I work at a casino and we use these on a Tatung 32" monitor in a Bally machine. There are some unidentified surface mount diodes used in locations D2, D3, D9, and other locations that are bad. I combined the diodes from both boards to have all good ones on one board, replaced MosFets Q2, Q3, U5 controller IC. No other obviously bad/shorted parts but it keeps blowing the Mosfets and U5 as soon as it is powered up. Also U5 was hard to get off of the board with a large amount of glue under it and it tore the board slightly. All traces appear to be intact but I want to verify on a schematic that every connection is where it needs to be. These are EOL, no longer available, so I'm trying to salvage these to keep our games running. Any info would be most appreciated! Thanks
              • 12200
              • U.S.
              #26
              Casino gambling IS the problem, will NOT help perpetuate it in any way. Sure it's a choice but it's also psychologically addictive. That's why so many old people forgo their medication to spend their social security check at a casino and why so many young people are homeless because they spent their rent money AND all the other disgusting problems it causes. If I were elected king of the world, casinos would be the first to be GONE FOREVER.
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • DynaxSC
                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                by DynaxSC
                Hi
                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                08-04-2025, 12:20 PM
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • eukal
                Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                by eukal
                Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                07-01-2023, 01:00 PM
