evesham v32eccb no power
  • snipersquad100
    • Nov 2013
    • 330
    Hello
    I got this evesham v32eccb tv given to me. it's a 2006 model.
    There is no power what so ever coming out of it. I can see scorch marks around two fet's and on the underside there is a hole in one of the chips (see pics) this is a stab in the dark but there is no burning on the chip, it looks like its been chiped some how "Pardon the pun". Is it possible that chip is ok??
    I haven't done any other checks yet, just a visual inspection.
    I will need a schematic if anyone got one cos if im going to repair this I will need to know what part the chip is as the hole on the chip had the numbers on it. Thank you...
    p.s. I think the board is a wannien 101vo 0544 or the board number is the one in the pic not sure.
    Re: evesham v32eccb no power
    No, the chip is destroyed. This will happen if the FETs fail. I have a Vestel PSU here with a blown SMPS IC too. It actually put a very nice black mark in the back metal behind the screen.
    • snipersquad100
      • Nov 2013
      • 330
      Only the one fet is blown "p14nk50zfp" but cant get the part on ebay or cpc, maybe no point if I cant get that ic number.
        It's a 14N50, just find a similar part with:
        - RDS(on): same or lower
        - Qg: same or lower
        • snipersquad100
          • Nov 2013
          • 330
          Closest I can find is STW14NK50Z, it has the same data sheet, think its just a different package. now just need to find out that part number on the blown chip. then I can order them and learn how to solder a small smd chip lol.
          • snipersquad100
            • Nov 2013
            • 330
            • snipersquad100
              • Nov 2013
              • 330
              Hi Tom, I bought this STW14NK50Z, I didn't realise it was a TO-247 package. Do you think it work if I bodged it in.?
              • snipersquad100
                • Nov 2013
                • 330
                I also need to know how to identify pin 1 on the chip ic2. as you can see in the pic there's no marks to let you know which way it needs to go. Do I use the writing as a reference and put it on the same way as the writing on the chip on the pcb?
                • snipersquad100
                  • Nov 2013
                  • 330
                  Just an update, I've soldered in the new chip, don't know if it was the right way around as there's no mark to see what is pin one, so I put it in with the writing the same way around as the one that came out. Changed the fet's to w14nk50z they a bigger package with metal back so cant be put on the heat sink as it shorts. Also had to change the fuse and the main cap as it was measuring in the nf region not 150uf, it wouldn't even register on the esr meter. I got a 5v on one of the pins but when I connected the psu to the tv it is fluctuating, tv wont turn on but there a orange flashing led on the front.
                  Any ideas anyone.
                  thanks.
                  • snipersquad100
                    • Nov 2013
                    • 330
                    I need a schematic
                      What voltage across the 450V capacitor?
                      • snipersquad100
                        • Nov 2013
                        • 330
                        333 volts dc, I did change this cap, the old one was 180uf 400v the one I put in was a 2nd hand one 220uf 400v and just within the esr range.
                          The PFC controller is not working then, did you check the resistor from the SOURCE pin of the MOSFET you replaced is OK? (Resistor goes from SOURCE to the negative of the big cap.)
                          • snipersquad100
                            • Nov 2013
                            • 330
                            Cant find a resister going to source to neg on big cap but there is on from drain to positive R10, which is measuring 0.24M ohms in circuit. It says 3323 on the resister, is that 332k ohms?
                            • snipersquad100
                              • Nov 2013
                              • 330
                              This pic might be better, it showing straight connection from source to neg on cap and the other fet going to the ic2 I changed.
                              • snipersquad100
                                • Nov 2013
                                • 330
                                Could this be the PFC path going to pin 1 of ic1?
                                R10 goes to R11 "throu hole" not the neg of big cap like I said 2 comments up.
                                R10 R11 R12 are connected in series "3323 0.24Meg 3323"
                                R11 is orange orange red orange gold
                                • snipersquad100
                                  • Nov 2013
                                  • 330
                                  I've been looking at a repair kit for this psu http://www.ohmsupplies.co.uk/REPAIR-...BOARD-UP220-AE
                                  •F1•IC5•Q5•R31•R32•ZD1•C28•C39 seem ok except for zd1 which is showing a short, don't know if its because its in circuit.
                                    My mistake, the PFC is Q8 + IC1, etc.
                                    You have only 330V across the main cap.
                                    This means
                                    - PFC is not turning on
                                    - Chance of both PFC & main 24V output (possibly 12V) also being bad is unlikely
                                    - Main board is sending PSON signal? Check this.
                                    - Check voltage at Vcc of PFC IC - possible IC2 is loading it down...
                                    • snipersquad100
                                      • Nov 2013
                                      • 330
                                      Well what do you know, I changed ZD1 which was a 1n4746 with a BZX85C and the tv came back to life. So all in all I changed the zener diode, main cap, 2 fets, 1 chip and a fuse. Now I know the tv works i'll have to buy the proper diode, fets as they are to big, proper cap as it to big to fit into the psu casing, and a proper fuse as I bodged in a 4 amp fuse soldering legs onto a normal fuse.
                                      Well all done, Thanks Tom66 for you help as usual.
                                      Just wish manufactures would be more relaxed in sharing their schematics especially ones like evesham who went out of business in 2008.
                                      Thank you
                                        Nice one.
                                        Evesham didn't make the TV, it is made by a (probably Chinese) OEM.
                                        In China, they tend to guard schematics with care, because there is so much copying. There is very little one company can do about another copying them. Releasing schematics, even just basic block diagrams, would be bad for them.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • eukal
                                          Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
                                          by eukal
                                          Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
                                          I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
                                          I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
                                          I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
                                          07-01-2023, 01:00 PM
