LG 42LH3000-ZA LCD TV Screen Issue
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Hi All
    I've got a 42" LCD TV model no. 42LH3000 with a screen issue. I've cleaned all the T-Con cable connections but the problem persists. Faulty T-Con board ?
    See attached photos of the problem.
    Mark
    Re: LG 42LH3000-ZA LCD TV Screen Issue
    Probably panel -- tab bonds.
    Doubt t-con would cause this.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      the line is overlaying the OSD,so id say tab bond fail too.
      gently twisting the frame may confirm it, if it changes ,then tab bonds.
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • safesurfer65
        • Feb 2014
        • 112
        • Scotland
        Thanks guys, info much appreciated.
        Found other information pointing to the tab bonds being an issue on this model. Don't think I fancy taking on this job. Probably break for spares !
        Cheers
        Mark
          I've done one like this before; it was really easy and is still working 12 months later.
          • bp1
            • Jul 2010
            • 46
            Was given one of these models a month ago with similar problems.
            First repaired the tab problem then about a day later encounted the picture going solarised with occasional very bright white screen. A new TCon from ebay china seller fixed that.
            Currently awaiting for some AS15 chips to replace on the old TCon.
            • Daigoro
              • Jan 2011
              • 9
              I attempted the tab bond fix on this model (different symptom) and it only lasted a few days. I never have managed to exactly locate the problem.
              • britishbloke
                • Oct 2011
                • 5
                At my place of work they bought a bunch of these in late 2009/early 2010 for displaying promo stuff. All eight failed within 2.5 years displaying faults similar to the one pictured above.
                Mind you the commercial Samsung displays they replaced them with have been no better lol.
                • hmp_a
                  • Aug 2014
                  • 4
                  • Portugal
                  Hi ,
                  I have a similiar problem. I have a LG 42LH3000-ZA with "negative" image. Do you know if the issue is the t-con board?
                  Can you check the pics attached and comment?
                  Thanks & Regards
                  Hugo.
                    That looks like the common AS15-F gamma IC fault, easy to replace if you have decent soldering skills.
                    • hmp_a
                      • Aug 2014
                      • 4
                      • Portugal
                      Hi Tom,
                      First of all thanks for reply.
                      The AS-15-F is the chip marked with red in the image attached, correct?
                      Do you know where i can buy an similar chip?
                      Thanks again.
                      Regards
                      Hugo -
                      • hmp_a
                        • Aug 2014
                        • 4
                        • Portugal
                        Hi Tom,
                        After verify again, the chip that I marked with red color is AS15-HF. It is the same that you mentioned (AS15-F gamma IC fault) ?
                        Thanks in advance.
                        Best Regards
                        Hugo .
                        • andyturbo
                          • Aug 2014
                          • 29
                          • England
                          Yes, that is the chip mentioned. You should start new thread for your problem.
                          • hmp_a
                            • Aug 2014
                            • 4
                            • Portugal
                            ok andyturbo. Thanks for your comment
                            tom, thanks a lot for your useful inputs.
                            • PREDATOR1
                              • Oct 2016
                              • 5
                              • Romania
                              Hello everyone!
                              My uncle owns this model and it started to draw some horizontal lines that shouldn't be there (check the pictures).
                              What do you think, is it the Tcon board or the panel is defective?
                              Thank you!
                              • PREDATOR1
                                • Oct 2016
                                • 5
                                • Romania
                                I'm sorry for the second post, but I can't edit the first one.
                                If you look carefully at the girl's face, you can see that is very pixelated compared to the original one.
                                • PREDATOR1
                                  • Oct 2016
                                  • 5
                                  • Romania
                                  It was the T-con board, I replaced it and everything is fine now.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    Thanks for the update. Glad you got it sorted.
                                    • Daren87
                                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                      by Daren87
                                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                      08-13-2023, 03:25 PM
                                    • kca
                                      by kca
                                      Hello all ~
                                      08-31-2025, 06:38 AM
                                    • wizard13
                                      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                      by wizard13
                                      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                      I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                      • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                      • Part Number (P/N): PYU13E-00C00PFR
                                      • Serial Number (S/N): 22028896H
                                      • System Configuration (SC): A1PYU13E1127
                                      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                      • Power Input: DC 19V –
                                      02-28-2025, 02:43 AM
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
                                    • cloudy
                                      HELP - Contrast/brightness issue with subtitles on screen
                                      by cloudy
                                      Hi everybody
                                      Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                                      Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                                      Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                                      It occours both on ubuntu and windows...
                                      01-01-2023, 05:12 PM
