Samsung LCD led un55d6000 won't turn on
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung LCD led un55d6000 won't turn on
    Yes exactly. If this PS doesn't sense the proper load from the backlight it will cycle continuously as you describe. What I don't understand is why your backlights flash at all - makes the possibility of bad leds more remote methinks.
    So if you had the cable from main board to power supply disconnected AND the backlights cycle I would replace the power supply first as it's least invasive. If that doesn't cure it you're looking at some strange led malfunction requiring a complete dismantling.
    • Momochi
      • Mar 2014
      • 16
      Thank you so much for all the advises! Will order the ps and update after installing that
      • Momochi
        • Mar 2014
        • 16
        So I replaced the power supply, the tv works fine except for one problem, the right top corner of the screen is darker than the rest of the screen. This is especially apparent during the brighter scenes. How can I fix this?
        • Ltank
          • Jun 2013
          • 776
          I believe the darker section of screen is caused by led backlight. You can not buy the strips. They are considered part of the screen. Generally no one has them for sale used.
          Lots of work to replace one. I tried repairing one without any luck. I thought I ordered the correct led. A lot may look the same but can be deceiving.
          • mmartell
            • Oct 2013
            • 3189
            This can be repaired but there is much work involved. I have no idea what your skill level is. LTank is right about replacement parts but it is possible to replace individual leds. Post back if you'd like to attempt repair.
            • Momochi
              • Mar 2014
              • 16
              Ok so when I was watching it this morning, the shading suddenly went away, but after about 10min or so it came back again is this still sign of a bad led? I'm not really repair savvy but I'm good at following directions
                Sounds like an intermittent LED or connection. A picture of the fault could help us.
                • mmartell
                  • Oct 2013
                  • 3189
                  Since the top and bottom halves of the strips are run in parallel an intermittent led or connection as tom suggests would cause the symptom you are seeing. I will post a pic of what mine looked like in the next post...
                  • mmartell
                    • Oct 2013
                    • 3189
                    Similar to this ? Notice the lower left portion of the screen and the downward diagonal "shading".
                    • Momochi
                      • Mar 2014
                      • 16
                      Yes!! Exactly like that, did you manage to fix it??
                      • mmartell
                        • Oct 2013
                        • 3189
                        See here
                        https://www.badcaps.net/forum/showthread.php?t=34566
                        • kensoulier
                          • May 2016
                          • canada
                          #32
                          mine flashes red five times but still won't turn on
                            Flashing 5 times after power switch is activated is normal start up for most of the SAMSUNG TV.
                            Did you open up the TV to take pictures of the boards and take good visual inspection any Voltage measurement yet? That will be a starting point.
                            BTW, it is the exact same TV model as in this thread?
                            • michael.johnson07
                              • Aug 2016
                              Hello. My samsung un55d6000 is not working. The screen stays black but when plugged in it has the led light next to the power indication is on. What could be the issue?
                                Did you do any Voltage testing at the connector of the power supply board that goes to the main board?
                                What is your power supply/LED driver board P/N? BN44- ??????
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
