Panasonic tc-p50g25 10 Blinks
  • tw2005
    • Oct 2011
    • 6457
    Re: Panasonic tc-p50g25 10 Blinks
    Originally posted by andrewnelles
    I noticed that too. So odd that on Slide 44, they show it as the probe point for reference ground. Doesn't seem to run to GND, and it doesn't appear to be a fault either. Odd.
    Replacement SC board on the way, I'll report back when it arrives. Looks like I'm clear to safely install it.
    where did you track one down? is it exchange or are you keeping the old one?
    • andrewnelles
      • Mar 2014
      • 12
      Bought a refurbished board on EBay, quicker than doing an exchange, and that's the most important thing right now.
      No idea what I'll do with the old board.
      • andrewnelles
        • Mar 2014
        • 12
        Board swapped, TV is working, thanks for the help!
        • tw2005
          • Oct 2011
          • 6457
          So simple almost boring when it goes to plan.
          • Andre Gilbert
            by Andre Gilbert
            11-20-2024, 08:52 PM
          • Biruslapio
            Panasonic P58V11B 8 and 12 blinks error "fix"
            by Biruslapio
            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
            04-13-2021, 07:13 AM
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
          • CrewmanRedShirt
            Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
            by CrewmanRedShirt
            Hello all,
            As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
            07-13-2024, 11:02 AM
