LG 47LM640T 3D Smart LED TV thin horizontal lines
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Hi all
    Got a LG 47LM640T 3D Smart LED TV that's got thin equidistant horizontal black lines covering the full screen. The picture underneath the lines is fine. Its just over a year old and just out of warranty (typical). I'm thinking faulty T-Con board. Any thoughts ?
    Mark
  • sordids999
    • May 2013
    • 2158
    Re: LG 47LM640T 3D Smart LED TV thin horizontal lines
    Might help you if you post some pictures of the fault
    • safesurfer65
      • Feb 2014
      • 112
      • Scotland
      hello
      I've attached a photo of the screen as requested. I'm presuming this particular TV has the T-Con integrated onto the main board as it doesn't have a separate T-Con board that I could see. Any ideas ?
      Mark
      • safesurfer65
        • Feb 2014
        • 112
        • Scotland
        Photo of Main board attached !
        • Moghere2002
          • May 2014
          • Uk
          Any help with this problem as mine is the same
          • freakaftr8
            • Oct 2012
            • 3743
            Either a main board or panel failure. I would be more susceptible to say mainboard because the lines are too spaced apart to be panel in my opinion. But could be wrong. Take a pic of the full screen so we can.see what it looks like
            • mintminty59
              • May 2014
              • 17
              • wales
              Have a look at my thread I just posted with 2 LG TV's. Dont be so quick to suspect the main board. Along the bottom of the unit is 2 PCB under the metal case directly along the bottom of the panel which seem to break down and cause this issue. If any fluid dripped down the screen from cleaning would cause this. Sadly the ribbons are glued onto the board meaning you are unable to replace.
              • tibimakai
                • Jan 2012
                • 3680
                • stuart
                  • Jun 2014
                  • United Kingdom
                  Hi I have the same problem the lines are 5mm apart and cover the complete screen it is a 55 inch has a solution been found
                  • Dj_danutzul@yahoo.co.uk
                    • Dec 2015
                    • 4
                    • United Kingdom
                    Hi. Did you sorted your lg 47 with the horizontal lines? If yes please let me know what was wrong with it. Thanks.
                      • Dec 2015
                      • 4
                      • United Kingdom
                      Hi. My tv 47 lm640t-za is developing the same problem with horizontal line. Any solutions from someone who sort it out? Thank you. The lines on my tv are more towards the left side of the tv. The right side it's not so bad.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Its frustrating because the person who made the thread never BOTHERED to update us. I would say your mainboard is faulty here as well.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Try heating your mainboard with a hair dryer see if the problem clears.
                            • Dec 2015
                            • 4
                            • United Kingdom
                            Thanks. I'll try that.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              No worries but dont forget to update us lol
                                • Dec 2015
                                • 4
                                • United Kingdom
                                Hi. Back with the problem. I heated first the mainboard . No effect at all. I ordered another main board and just replaced it , didn't cured the problem. What is left are the 2 pcb s under the screen which are kind of irreplaceable because are together with the screen. They've got though some small resistors Capacitors and diods I think. Any chance someone can have a play on them? Or is just waste of time. Would any magnetic field from a external hdd affect them? I had my external drive under the tv for few hours.
                                • SimonF1
                                  • Feb 2016
                                  • 3
                                  • England
                                  I Have a LG Model 55LM640S-ZA
                                  I have same problem it just started last night. same as the photos here but my lines are more on the right side and fade out across the screen towards the left side.
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    Panel Problem, Completely Unrepairable.
                                    Pretty disgusting as these sets are only Just outside Warranty.
                                    Complain Bitterly to Maker and Place of purchase, quoting 'Not Of Merchantable Quality' and 'Last a Reasonable Time' lots and lots....
                                    --IF they Don't play ball--Get Trading Standards involved.
                                    We Gotta make these damned manufacturers take notice and provide Better Quality crap--instead of the mediocre crap they currently serve us up, that lasts 5 minutes, and becomes unrepairable just outside warranty!
                                    To give you an idea--and this Does work--
                                    I rescued a 50" LG Plasma set from recycling. Its Date of manufacture was 1 year, six? months before I had rescued it.
                                    I bitched to LG for a week or two, they took it back--and repaired it FOC.
                                    I had No Receipt or date of purchase, but the serial number confirmed manufacture date.
                                    It CAN be done....
                                    TELEFIX
                                    • SimonF1
                                      • Feb 2016
                                      • 3
                                      • England
                                      I got mine from ebay 21 Nov 2013 cost me £840.
                                      I can't afford this sort of payout every 2 years, so i will not be buying any more expensive electronics unless it comes with a 3 year warranty or more.
                                      I've contacted LG and the ebay seller, but im not holding my breath as im over 1 year out of warranty.
                                      My guess is all they will do is try and talk me into buying a new tv or an expensive repair bill, but that's see how this goes
                                      • SimonF1
                                        • Feb 2016
                                        • 3
                                        • England
                                        Just as i thought, all they are interested in is for me paying to get it fixed.
                                        Just got an email from LG.
                                        "I am very sorry to hear you are having issues, but if the TV is outside of it's one year warranty period then we will not be able to assist. All I can recommend is that you try a hard factory reset, which you can find in Settings > Option > Factory reset. Failing that you will need to look into a third party repair service like Curry's Knowhow to get the TV fixed. "
                                        I would rather buy a none LG rather than spending even more on this now i know their devices only last 2 years then die.
                                        Very disappointed.
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                          HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
                                          This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-06-2024, 06:50 AM
                                        • ggil44
                                          Sony XBR-65X750D Horizontal lines bottom of screen
                                          by ggil44
                                          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                                          05-30-2023, 07:51 PM
                                          HP mt44 Mobile Thin Client Mobile thin client Specification for Upgrade or Repair
                                          This specification for the HP mt44 Mobile Thin Client Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client boardview and mt44 Mobile Thin Client schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
