Samsung UE75TU6905 reboot loop
  • Diah
    • Feb 2013
    • 6370
    however this could be primary issue if there wet under them... but the primary as i think because he get logo tizen then reboot... so ESD HDMI resolution protection are bad.
    i still have 5 pieces original in case you are fit to replace such tiny things..
    • brkie
      Random guy
      • Sep 2024
      • 14
      • Sweden
      #42
      Originally posted by lotas
      Remove this tape and take close-up photos of these areas.
      • Diah
        • Feb 2013
        • 6370
        OOPS... different Panel !!
        if you just disconnected the U ribbon at the middle of the boards... did the TV work and display 3/$ picture ? need to test from both side a time.... if yes you have working TV with 3/$ screen.. then
        look on the whole boards of both side if you can see such this in PHOTO
        • brkie
          Random guy
          • Sep 2024
          • 14
          • Sweden
          #44
          When dissconecting left one, (from behind tv), 2/3 screen is working. See picture. No boot loops
          when dissconecting right one, whole picture is bad, no boot loops.
          only found 3 of those, not together but separated.
          One / panel.
          • lotas
            • Jan 2016
            • 4598
            • Russia
            #45
            Try to mask this area on the cable, on the side where the fault is...
            • Diah
              • Feb 2013
              • 6370
              One / panel.
              so when you disconnect the left side ( looking from back TV ) you have part in white color and the reset good picture... correct?
              and when you disconnect the right U ribbon you have complete bad picture no reboot correct?
              show please photo for complete screen display at time you disconnect the right U ribbon.
              BTW. at first i wrote to you about doing hard reset from service menu... you can by disconnect any left or right U ribbon to put the TV in Standby and from Standby call the service menu...
              i still don't think you have issue on panel... but the T-CON on the mainboards cause the reboot... so let rest the TV as hard reset first.. go back to fist page at this threat and read they write to you also how to log in service menu when the TV in standby state.
              • brkie
                Random guy
                • Sep 2024
                • 14
                • Sweden
                #47
                It didn’t work. I started with all the pins masked as you marked, but I only got a bad, black picture. Then I cut the tape smaller and smaller until it was half of your mark and tried moving it left within the marking, but the result was the same as before.
                • brkie
                  Random guy
                  • Sep 2024
                  • 14
                  • Sweden
                  #48
                  That's correct. Here are the pictures—note that the TV is upside down now. I'm slowly giving up on this TV.
                  I accessed the the service menu, but I don't have enough time to find where to reset because it keeps rebooting. Can you give me a hint on which menu I should follow to reach the reset button? If I leave the TV off for a while, I get a bit more time before it reboots.
                  • lotas
                    • Jan 2016
                    • 4598
                    • Russia
                    #49
                    Which side did you camouflage on, this one? Resetting to factory settings will not help you!
                    • brkie
                      Random guy
                      • Sep 2024
                      • 14
                      • Sweden
                      #50
                      Ye, on right side from behind the tv.
                      • lotas
                        • Jan 2016
                        • 4598
                        • Russia
                        #51
                        You can measure the resistance on each of them and compare them on the other side, with the cables disconnected.
                        • Diah
                          • Feb 2013
                          • 6370
                          he isolate the white color side by disconnecting the U ribbon but still have reboot.. how you will know reset from service menu will not help if he didn't do it till now... !
                          OP reset will be the last down option at S.M
                          • lotas
                            • Jan 2016
                            • 4598
                            • Russia
                            #53
                            But is it possible from the photo that in post 48 a reset can help if the panel is not working properly.
                            • Diah
                              • Feb 2013
                              • 6370
                              when he disconnect the U ribbon cable he show us clear picture on 3/4 screen but with white not clear on the disconnected side.... but his set even show the clear picture did reboot after 12 second
                                • 12187
                                • U.S.
                                #55
                                Seems like it's the same old thing as in this, YEP you guessed it, youtube video, "made usable" the usual way. Seems like you are not blocking the proper signal/s unless it's something bad on the board that you have isolated it too, issue seems to certainly be in the screen itself or the driver board, this is a TEST post, lets see what happens: https://www.youtube.com/watch?v=tgjZDMCvFv8
                                  • 12187
                                  • U.S.
                                  #56
                                  Just fixed my Keurig beverage maker with the simple rerset, (was dead as a doornail) unplug hold power for 30 seconds to 1 minute, plug back in works fine.
                                  • kevin_allein
                                    Samsung GU58TU7199 reboot loop
                                    by kevin_allein
                                    Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                                    The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                                    03-24-2024, 12:19 PM
                                  • Takeatry
                                    Yet another Samsung QLED Boot Loop
                                    by Takeatry
                                    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                    10-04-2024, 02:57 PM
                                  • natiz
                                    Samsung QE50Q60AA - Reboot loop
                                    by natiz
                                    I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                    Disconnecting the LVDS cable stops the restart loop but no image.
                                    I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                    Tested the caps on the left buffer board, no beeps.
                                    What else can be checked?...
                                    08-30-2024, 09:26 AM
                                    09-07-2024, 05:50 AM
                                  • Yanleb
                                    Samsung 4K UN55NU7100F stuck in a reboot loop
                                    by Yanleb
                                    Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
                                    I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
                                    I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
                                    On a few occasions I found that reconnecting the disconnected LVDS...
                                    03-19-2022, 02:13 AM
