Samsung UE75TU6905 reboot loop
  • brkie
    Random guy
    • Sep 2024
    • 14
    • Sweden
    I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
    I read on Samsung's website (reviews) that everyone has the same problem right after the warranty expires. Since the TV is relatively new (barely used), I was considering whether I could repair it. Samsung wants 200 euros for an inspection, plus 300 euros for labor costs, and then additional material costs.
    I was wondering if there is something I can do myself? I intend to troubleshoot whether it's the power cord, backlight, or motherboard, but how should I proceed after that? Does anyone know what the usual issue is and whether it's worth trying to repair it myself?
    • 12269
    • U.S.
    I always try a simple reset first, unplug tv from power, hold power button on tv down for 30 seconds, wait 2 minutes plug tv back in and try it.
    • brkie
      Random guy
      • Sep 2024
      • 14
      • Sweden
      Thx, I did all resets Samsung support suggested and that I could find on internet. Did not help
        • 12269
        • U.S.
        Does that mean you tried the one I just typed, There's no sense in trying to help someone that can not follow direction. When every little test is a chore to get done, then I have to let others help, as my patience is short today.
        • EazyBone
          • Jun 2023
          • 1353
          • United states
          Sony, when is the last time someone came here, did your reset and was like it's fixed! And left?
          So what you can do is disconnect the main board from the PSU and plug it in. The backlights should come on and stay on. This eliminates PSU/backlights circuit.
          Unfortunately rebooting means the TV panel has shorted on Samsung somehow. If Samsung gives you a quote of 200/300/parts then you should throw that TV away cause it's the most expensive part, the screen and will likely cost you more then the TV is worth. It'll be 200/300/600. Doesn't Europe have consumer protection laws or something?
          You can Google, fixing TV with tape. Look at a video (or a thread on here that shows how) and test that way. If it works, likely it's the panel and you are effed.
          • brkie
            Random guy
            • Sep 2024
            • 14
            • Sweden
            Sorry, yes it means that I also have tested that one and it did not solve the problem.
            • lotas
              • Jan 2016
              • 4744
              • Russia
              But it won’t solve it, the problem in the “NU” series, as always, is connected with a malfunction of the panel, mass defects.
                • 12269
                • U.S.
                Pay attention and do your research, that simple reset has fixed TONS of tvs, so why ask such a stupid question?? I know you're an eager beaver but there's still VOLUMES that you don't know.
                  • 12269
                  • U.S.
                  Originally posted by lotas
                  But it won't solve it, the problem in the “NU” series, as always, is connected with a malfunction of the panel, mass defects.
                  So can you help him troubleshoot OR do you just want everyone to know that YOU know what's wrong? As in help op prove the panel is bad, because not ALL are bad and if you don't prove it, well then it's just another GUESS.
                    • 12269
                    • U.S.
                    My bad for being snippy Brkie, I wasn't quite awake this morning.
                    • lotas
                      • Jan 2016
                      • 4744
                      • Russia
                      And if, according to your method, you hold the button for 30 seconds and the panel will be restored and the TV will work?
                        • 12269
                        • U.S.
                        Well you are not as bright as you imagine, are you. I'll explain a little something that good techs have known forever. ALWAYS start with simple things, if you can not grasp this concept then you must have issues. You have some knowledge BUT you are kind of only on a single thought path, which isn't a good path for troubleshooting. No matter the issue you first jump on it must be firmware related, well guess what...it isn't always the case. If you figure something semi intelligent to ask, feel free BUT if it's going to be the same as you and ezbone just asked, don't bother. So no more inquiries ok.
                        • Admin
                          • Oct 2003
                          • 5334
                          • United Kingdom
                          come on guys i hate having to babysit your posts. get a grip and stop fighting
                          • Admin
                            • Oct 2003
                            • 5334
                            • United Kingdom
                            Hello admin, can you get this guy off my case? He has some errant bs to say about EVERY post I write, and I'm just SICK of it.
                            Go to account settings and add to your ignore list if desired
                              • 12269
                              • U.S.
                              Thought someone could at least give him a warning, well I'll put m on ignore then.
                              • Admin
                                • Oct 2003
                                • 5334
                                • United Kingdom
                                I read through the entire garbage chat today. 10 minutes of my life i'll never get back. I can give you a warning if you want?
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  take it easy Guys , doesn't worth argue on shit Samsung...
                                  EasyBone suggest you to disconnect the socket between mainboards and power boards.... see if the LED backlight come on and remain on..
                                  this is TU not NU.... i have 2 75 even if the screen smashed will never make reboot.​
                                  the OP stated he just in total maybe only 10 hours in use... its wrong to judge on matter... yes we know all how shit the panel at Samy U aerie... but need step by step before scrap TV
                                  • Diah
                                    • Feb 2013
                                    • 6435
                                    you used the Tv as presentation..as you said... with which source ? HDMI or USB ?
                                    from yours fault description it show the logo then Tizen then make reboot... this mean after Tizen usually the set with switch on the last source where it working on.... so if it was HDMI it could the source switch damaged or it set on solution which TV didnt understand it... try trik the TV to put it in STBY and from STBY state call service menu from there do hard reset.
                                    or use the last source input with content low resolution not 4K lower you have even if 480p
                                    • Admin
                                      • Oct 2003
                                      • 5334
                                      • United Kingdom
                                      I've removed the further posts. nomoresonys - you are welcome here but you have to tone it down a bit. no personal attacks on the site or users. I do not want to start banning long standing users but i will to keep the peace if needed.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • Method 1: INFO → MENU → MUTE → POWER – usually works for European models of Samsung TVs and also works with some LED TVs in the US.
                                        • Method 2: MUTE → 1 → 8 → 2 → POWER – suitable for TVs in the USA.
                                        • Method 3: DISPLAY → P.STD → MUTE → POWER.
                                        • Method 4: SLEEP → P.STD → MUTE → POWER.
                                        • Method 5: DISPLAY → MENU → MUTE → POWER.
                                        • Method 6: MUTE → 1 → 1 → 9 → POWER.
                                        ​service menu codes
                                        • kevin_allein
                                          Samsung GU58TU7199 reboot loop
                                          by kevin_allein
                                          Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                                          The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                                          03-24-2024, 12:19 PM
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • natiz
                                          Samsung QE50Q60AA - Reboot loop
                                          by natiz
                                          I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                          Disconnecting the LVDS cable stops the restart loop but no image.
                                          I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                          Tested the caps on the left buffer board, no beeps.
                                          What else can be checked?...
                                          08-30-2024, 09:26 AM
                                          09-07-2024, 05:50 AM
                                        • Yanleb
                                          Samsung 4K UN55NU7100F stuck in a reboot loop
                                          by Yanleb
                                          Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
                                          I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
                                          I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
                                          On a few occasions I found that reconnecting the disconnected LVDS...
                                          03-19-2022, 02:13 AM
