Hitachi l42vp01ub
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    #41
    Re: Hitachi l42vp01ub
    Originally posted by sordids999
    Spoke to his girlfriend last and got a different story lol quote:
    It worked properly but we kept losing signal and id have to wiggle the ariel on the bk to get picture back and sometimes it would go and I wouldnt be able to get it back for a few hours also when using scart it would cut out, wasnt all the time but every few days. Picture wise it was perfect no red lines or anything. When I used the pc through it I never had 1 problem
    i think there is crud in the hdmi ports causing this.
    also check around the tuner on the main board for dry joints,lift off the sheild on the tuner and check the ariel connection there,re-solder that connection..
    you ran the pc via the VGA on the tv?.
    clean an reseat every connection to rule out also.the LVDS ribbon top priority both ends.
    with tv running,flex all boards with insulated tool to see if fault appears again
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • sordids999
      • May 2013
      • 2161
      #42
      right done most of what multimeter said but found one problem if i plug in scart lead to (avi 1) i get the red lines but if i use (avi 2) its fine
      http://www.youtube.com/watch?v=UuDOuVUm35I
      • sordids999
        • May 2013
        • 2161
        #43
        right i think im giving this back to my friend got a replacement board today still no good thats two ive tried with both boards i get a blue effect solarized picture but if i put in the original board everything is ok but if you use avi 1 you get the red lines
        never mind i tried
          Looks like panel setting is wrong. MENU 4-7-2-5 (or 7-9-3-5 or 1-3-2-5) and change panel option.
          • sordids999
            • May 2013
            • 2161
            #45
            Ok tom ill try that I'll have to use old board to see service menu the replacement board is from a 37 inch Hitachi so change it to that ?
            • sordids999
              • May 2013
              • 2161
              #46
              @tom in the service menu it won't allow you the option to change in the panel
                Hmm, may be write protected - if EEPROM swappable you can try with a blank one.
                • sordids999
                  • May 2013
                  • 2161
                  #48
                  Easy to do ?
                  • sordids999
                    • May 2013
                    • 2161
                    #49
                    It's a strange one put the old main board in and you can change the panel settings but with the others it's a no
                      The EEPROM is the chip in the socket, left hand side of main board.
                      • sordids999
                        • May 2013
                        • 2161
                        #51
                        ok thanks tom
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • kdaniel
                          Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                          by kdaniel
                          As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                          There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                          After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                          Left...
                          11-16-2022, 09:23 AM
                        • Stanley1843
                          by Stanley1843
                          06-29-2024, 11:54 AM
                        • jeyoung12
                          Samsung QN50Q60t lines on screen
                          by jeyoung12
                          Hi all
                          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                          So....i don't know what end of the C ribbon to work with...
                          02-26-2024, 10:38 AM
                        • Rubenlily
                          Samsung QE50Q67TAU - horizontal lines
                          by Rubenlily
                          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                          I'm no expert but I've done the tape...
                          08-16-2023, 01:12 PM
