LG 42LT75 no backlight
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: LG 42LT75 no backlight
    Maybe the IC or something attached to Pin 8 is leaky?
    -David VanHorn
      Check PIN 2 and pin 3 DC voltages to see if there is any activities there. pin 4 is the ground ref point.
      • tn245
        • Oct 2013
        • 530
        Thanks budm. On pins 2 and 3 on the good board I measure a jump to approx 5V on switch on, then it drops to 0V. (this is out of chassis so protection must be kicking in).
        On the faulty board it's only in the mV range.
          OK, so it is not driven, if you look at pin 2 and 3, you will see the traces that go to a bunch of transistors which looks like they are driven by transformer T702. There are 2 ICs one is 8-pin SMD and one is 16-pin SMD which looks like it drive the T702. Can you get the P/N of those 2 ICs, see picture #1 on post 15.
          • tn245
            • Oct 2013
            • 530
            The 8-pin IC is S393, the 16-pin is OZ9925GN.
              OK, let me look up the spec sheet for those 2 then we can check the VCC Pin to see if it is getting the voltage or not, it is good that we do have good working board to do the comparison test.
              • tn245
                • Oct 2013
                • 530
                Great! I looked up the OZ9925 when I first started on this board and didn't find a datasheet, but I did find this page with pinouts: http://www-user.tu-chemnitz.de/~heha...arieren/OZ9925. I also did do some testing on that previously and it is getting 12V Vcc if I remember.
                I'll probably have to put it aside till tomorrow now as I've got people coming round in a bit and have to put away all the circuit boards and stuff. Will do some more voltage testing tomorrow.
                Feel like we've made some progress. Thanks again!
                  • 31015
                  s393 8pin - sounds like an LM393
                  • tn245
                    • Oct 2013
                    • 530
                    Yes, I think it's the same type of thing. Datasheet for S393 attached.
                    So I found a chance to take some measurements. S393 is getting 5V VCC on pin 8, and OZ9925 is getting 11.75V on pin 2. This is the same on both boards so looks like the ICs are getting their supply voltages ok.
                    • tn245
                      • Oct 2013
                      • 530
                      On the OZ9925 pins 3 and 5 (push-pull driver outputs) lead to that transformer T702, and on the working board I measure an initial 5V on both pins. On the faulty board it's only mVs.
                      I went ahead and measured all the OZ9925 pins on both boards. Here are the measurements plus pin assignments from the link. Where it says (then drops), I guess it's because I haven't got lamps connected, and it's going into protection.
                      Code:
                      Pin Working     Faulty
                      1  5        5          VREF	Reference Output +5V
                      2  11.7       11.7         VIN	Power supply +12V
                      3  5 (then drops)  0.4         NDR2	push-pull driver output #2
                      4  0        0          PGND	Power GND
                      5  5 (then drops)  0.2         NDR1	push-pull driver output #1
                      6  0        0          AGND
                      7  1        1          RT_CT	Sawtooth generator R and C
                      8  0.58       0.59         LRT_LCT	(Triangular wave for burst-mode dimming)
                      9  2.3 (then drops) 1.24         DIM	Dimmer control input
                      10  2.3 (then drops) 0          VSEN	Voltage feedback input
                      11  2.8       2.8         OVT	(Over Voltage Threshold?)
                      12  0        0          TIME	Switch-On input/output
                      13  2 (then drops)  0          SST-CMP	seems to be a power-good output, H = lamps are bright
                      14  0        0          ISEN on/off control input, H = ON, L = OFF
                      15  5        5          ENA	Enable
                      16  5 (then drops)  0.74 (then drops)  VLS	Voltage Low Sense
                        So some how there is no drive output to drive the transformer, it should have sent out the drive then goes into shutdown after the error is detected. Do you want to try new IC?
                        This one example of how it is used:
                        • tn245
                          • Oct 2013
                          • 530
                          Yes, I think I'll try a new IC.
                          My IC I'm pretty sure is OZ9925GN, this ebay link is for OZ9925CN
                          http://www.ebay.co.uk/itm/1-piece-Ne...-/190985512156
                          But on their photo it even looks like it could be GN, not CN. Utsource has both CN and GN listed.
                          I guess either should work anyway right?
                          • tn245
                            • Oct 2013
                            • 530
                            The ic must have been ok. I just put in a brand new one and there's no change. Measured voltages on all the pins are as before.
                            So I'm wondering if some of the other voltages on input pins might be suspect causing the ic to not be driven correctly. Maybe pin 9 - Dimmer control input which from a chinese page I found should be in the range 1.5V - 3.5V. Or maybe pin 10 - VSEN or pin 16 Voltage Low Sense?
                            This page has lots of info on the ic, but it's a little hard to understand the google translation of the Chinese:
                            https://translate.google.com/transla...-text=&act=url
                            • tn245
                              • Oct 2013
                              • 530
                              I think the ic is not on because of pin 16 being low. On the good board it's 5V at start-up, but on the bad one it's almost nothing.
                              I tried grounding the base of Q312 causing pin 16 to stay at 5V. Now I get the 5V at pins 3 & 5 driver outputs on the ic, and I get those input voltages on the FAN7382 - though there still doesn't seem to be any oscillation happening at the inverter transformer and no light on a CFL.
                              I think pin 16 of the OZ9925 is normally kept high by the feedback circuits coming from the output of the inverter transformer (top of second pic) but there's no feedback coming via C402/407 at all.
                              Any thoughts on what's going on here? What could I check next having ruled out the PWM ic?
                              • tn245
                                • Oct 2013
                                • 530
                                Hi! Any further thoughts on this? Budm??
                                Otherwise I think I'm going to give up on this one and just replace it. I hate to give up unless I know it's unfixable though. Seems a shame to chuck it.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4951
                                  • New Zealand
                                  #36
                                  I guess you need to find out why Pin 16 (and maybe 9 and 10) aren't getting the same signals as the working one.
                                  Since you have a working one, you can compare voltages in the circuits associated with those signals
                                  -David VanHorn
                                  • tn245
                                    • Oct 2013
                                    • 530
                                    From what I can tell, Pin 16 on the working board is kept at 5V by voltages tracing back to C402/407 which are connected to the outputs of the inverter transformer. On the faulty board there's nothing coming out of the outputs so Pin 16's voltage is switched off. As I said I can force the ic on by cutting out that feedback signal, but I still get no output on the transformer which leads me to think the problem is elsewhere.
                                    I don't really get how that works though, it seems to be a paradoxical loop in my mind. If the ic needs the feeback from the inverter to power on, but the inverter needs the ic to drive it, how does it ever get started?
                                      Not at this point, comparison test with working board and SCH will help at this point.
                                      • tn245
                                        • Oct 2013
                                        • 530
                                        SCH = schematic I guess? Yeah, I haven't found one anywhere. One would definitely be helpful! I've been trying to do comparisons but just not sure where to focus on really. Thanks for all your help anyway. I have learned a bit on this one even though I might not get it going.
                                        Can anyone explain the basics of how the feedback loop I described in my last post works though? I'm interested.
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 4951
                                          • New Zealand
                                          #40
                                          I don't know how the feedback works, from what you say it doesn't make sense, so maybe there is some extra 'bootstrap' circuitry or such there you are missing?
                                          -David VanHorn
                                          • lostone
                                            Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                            by lostone
                                            Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                            First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                            When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                            05-19-2024, 11:40 AM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
                                          • Comp_Pro
                                            No Backlight Macbook A1990 820-01041
                                            by Comp_Pro
                                            Hello all,
                                            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                            Tests performed:
                                            There is no backlight even with a good screen.
                                            Backlight IC is receiving the correct support voltages.
                                            Fuse F8400 ok
                                            Current sense resistor R8400 ok
                                            Backlight IC is receiving 3.3V on enable pin.
                                            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                            Backlight IC receiving 5V from PP5V_G3S
                                            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                            05-06-2024, 10:23 PM
                                          • jimbofz
                                            lg 32LC46 backlight inverter board fault
                                            by jimbofz
                                            Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                            still no b/l this uses inverter type:1315 B1-16A,
                                            im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                            all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                            this allows protect to be temporary overridden.
                                            b/l now comes on
                                            but the left hand side of pic is gradually darker than the right side
                                            i have the cct for the tv
                                            but it does not have inverter cct.
                                            i opened it up to inspect the ccfl tubes
                                            and they dont have any...
                                            12-19-2021, 06:58 AM
                                          • cheebster
                                            iPad Pro 12.9 5th Gen Backlight Issue
                                            by cheebster
                                            Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                            Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                            Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                            The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                            Anyone...
                                            05-20-2025, 09:17 AM
