usp440m-42lp psu
  • joehezzer
    • Jul 2012
    • 251
    • England
    #81
    Re: usp440m-42lp psu
    my fault lol still learning . Outter pins read 02.2v dc the inner oned read 03.5v Ac
    • paulstef
      • Dec 2013
      • 724
      disconnect AC. check the two big white resistors. they are probably open.
      • joehezzer
        • Jul 2012
        • 251
        • England
        #83
        R106 and R105 you mean
        • paulstef
          • Dec 2013
          • 724
          yes.
          I will only have the board for a few more days. if we can find out whats wrong today would be good.
          • joehezzer
            • Jul 2012
            • 251
            • England
            #85
            Ok cool going to remove board as I cannot acces it
            • joehezzer
              • Jul 2012
              • 251
              • England
              #86
              taken one out and i got the reading of 5.6ohms both are reading this
              • paulstef
                • Dec 2013
                • 724
                Ok, look. The AC voltage that comes in goes more or less directly to the two middle pins of the bridge rectifier. You have to find out where this path is interrupted. If you cannot measure AC between the middle pins of the rectifier it should be fairly easy to find out.
                • joehezzer
                  • Jul 2012
                  • 251
                  • England
                  #88
                  Tnr101 and tnr102
                  • paulstef
                    • Dec 2013
                    • 724
                    Tnr101 and tnr102
                    I cannot guess what you want to say. They are in parallel with the AC voltage. You only need to look at what's in series . Which component can cause an interruption from AC in to the bridge rectifier. Just follow the path. Forget the relay, it only jumpers the white resistors, which you said are ok.
                    Simple resistor measurement will get you there
                    AC OFF!!
                    • joehezzer
                      • Jul 2012
                      • 251
                      • England
                      #90
                      AC OFF!!
                      ok, i see what you are saying, it can only be one of the components leading up to the bridge rectifier.
                      • joehezzer
                        • Jul 2012
                        • 251
                        • England
                        #91
                        So I have decided to change the components leading to the bridge rectifier.
                        • paulstef
                          • Dec 2013
                          • 724
                          Right ok test out put again and got 263v Ac atleast I have a reading this time lol
                          In this post you said you have AC input voltage. So replacing anything between AC IN connector and this point won't help you. There are only the resistors between this point and the rectifier (where you measured nothing).
                          You said the resistors are ok. So I don't see where replacing any parts will lead you.
                          You are either not measuring correctly or there is something else we don't see.
                          When measuring resistance from one of the middle pins of the bridge rectifier to the AC input pins, what do you get?? Then from the other middle pin of the rectifier, what do you get?
                          • joehezzer
                            • Jul 2012
                            • 251
                            • England
                            #93
                            I measured the wrong resistors. I had the board the wrong way round, as there are 4 of them, I tested the wrong ones as I was rushing yesterday
                            • paulstef
                              • Dec 2013
                              • 724
                              Ok, so if the two white resistors or one of them is open there are other component that need to be checked. First of all the bridge rectifier.
                              • joehezzer
                                • Jul 2012
                                • 251
                                • England
                                #95
                                I have changed the bridge rectifier to a known working one. So will check again later after me dinner
                                • joehezzer
                                  • Jul 2012
                                  • 251
                                  • England
                                  #96
                                  Originally posted by wills123
                                  i recently just did one of theese, managed to get a psu from ebay for £30 delievered, the one i had , b/r shorted and a load of mosfets ,so got another board
                                  http://www.ebay.co.uk/itm/4004140660...84.m1497.l2649
                                  it wasnt really worth doing but my missus likes the tv an for keeping her quiet............... priceless
                                  ok so i gave in on trying to find out what was wrong with psu, and ordered the above psu popped it in this morning it works, for the sake of £30 with free postage i cannot moan cheers all that helped me fault find the old one, cheers paulstef
                                  • dicky96
                                    Need to buy buck regulator MP2329CGG but struggling to find supplier
                                    by dicky96
                                    Hi guys
                                    I need one of these MP2329CGG for a repair job. It's a 24V 6.5A buck converter. But I have not been able to find a supplier who has that component.
                                    Actually I would buy a few as I always think if I found one faulty already I will probably find more in the future
                                    I had one supplier on Aliexpress who gave me a price $2 each, but I have been waiting some days since I asked for shipping price and they don't reply
                                    Does anyone know where I can buy that part in small quantity (let's say 5 of them), or any equivalent I could use? it supplies the Standby...
                                    03-05-2021, 08:44 AM
                                  • Faileng
                                    Struggling with a soldering job, need help.
                                    by Faileng
                                    Hello, although I've never been formally taught soldering techniques, etc... I've not really run into too much trouble soldering, with the exception of this job...
                                    I've got a supposed blown transistor on my fuel pump on my car and I'm trying to replace it. It's a gel encased circuit booard with very fine connections. Please see photo uploaded.
                                    I've cleaned up the area that I'm working on with alcohol scraped off the wires, etc..
                                    I cannot get any solder to now stick any of the connections, I've used various grades of solder and flux combination, nothing...
                                    02-06-2020, 02:07 PM
                                  • rockman97
                                    Need BIOS dump for ASROCK FM2A55M-VG3
                                    by rockman97
                                    Hello guys,
                                    I am struggling to find bios BIN file for ASROCK FM2A55M-VG3 (i had the normal VG3 not the VG3+)
                                    When i download from official website, and put that in EZP2019+ programmer software it says ''FILE LENGHT, BEYOND RANGE OR IT WILL BE IGNORED''
                                    That means that file i downloaded is larger than chip says, even tho chip is 8mb and file is 8mb.
                                    It has the Winbond 25Q64FVAIQ chip what i need to select the prgoram?
                                    I created a backup but when i rewrite its not work.
                                    Today, 04:31 PM
                                  • Rickkap
                                    Help in identifying a component- ASUS ROG G634J
                                    by Rickkap
                                    I have an ASUS ROG motherboard and it has a shorted/burnt component which I'm struggling to find or identify.
                                    Any information would be greatly appreciated.
                                    If anyone has the schematics/boardview that would really help....
                                    Today, 01:24 AM
                                  • Dreigas
                                    Laptop, Bios and some phones schematic database
                                    by Dreigas
                                    About a year ago, I was struggling to find schematics whenever I needed them. As a programmer, I saw an opportunity and wrote a few scripts to automatically gather a large database of them. Today, I've decided to share it with everyone, because good things should be accessible to all.
                                    What's included? Over 14,000 laptop schematics, as well as some BIOS files, and about 1,000 phone schematics.
                                    Everything is compressed in a RAR format and is over 140 GB. (Since it's such a large file, your browser might show a warning.)
                                    I plan to host the...
                                    08-20-2025, 09:58 AM
