Led TV Xiaomi L43M5-5ASP with pixel noise
  • Smartec82
    • May 2015
    • 24
    • Portugal
    This TV turns on, but instead of an image, colored dots appear, as you can see in the photos. Does anyone have any idea what it could be?
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
  • courtcircuit
    Philips HTS8000 home cinema noise problem
    by courtcircuit
    Hello
    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
    Removed each of tyhe boards
    02-08-2025, 08:22 AM
  • rumi409
    LG OLED C1 Pixel Cleaning Made Picture Worse
    by rumi409
    ​​​​​​ Hi,
    I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
    11-15-2024, 01:09 AM
    Xiaomi Mi 9 Lite / Xiaomi Mi CC9 Schematic & Board View
    Xiaomi Mi 9 Lite / Xiaomi Mi CC9 Schematic & Board View...
    10-05-2024, 10:59 AM
