Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
  • Cornito
    • Jan 2024
    • 90
    • France
    Hello Team,
    I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
    Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
    Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result.
    Using an LED tester, everything seems good, with 73.5V per line (2 lines on this TV). The power supply delivers around 83V per line, but there is no backlight, or just a brief backlight at startup for about 1 second.
    The only way to have a kind of working backlight is to use my multimeter in resistor mode and test between the return of the LED and the chassis.
    Regarding the main capacitor in the hot area, the voltage is 320V, with a brief spike up to 400V. Could this be the root cause of the issue?
    Before buying a new power supply, do you have any advice on how I can resolve this backlight problem?
    Thank you for your assistance.
    Best regards,
  • CapLeaker
    Leaking Member
    • 7986
    The LEDs are current controlled, not voltage controlled. The OBwhatever number IC is detecting a fault somehow and turning the backlights off. Download the data sheet and it will tell you how it works and what voltage range you need to see on what pin. I would start with the enable, ovp / uvp and the current sense pins.
    • Cornito
      • Jan 2024
      • 90
      • France
      Hello Capleaker, thank you for the advice.
      Do you know where i can find the data sheet with correct level of detail ?
      I'll need to change the pull up resistor to correct this protection ?
      • CapLeaker
        Leaking Member
        • 7986
        Look at alldatasheet.com OB3362RP from On Bright.
        i think it is a OB3362F datasheet, but that doesn’t matter much, just different casing still 16pin
        • Davi.p
          • Sep 2009
          • 4270
          • Italy - Milan
          ???... there's no minimal reason that it can reach 400v on hot side with no PFC present.. sounds like a joke...maybe a joke of your MM
          • Diah
            • Feb 2013
            • 6343
            Originally posted by Cornito
            Hello Team,
            this tell you have one SMT R open / or changed Value at the BL circuit, the SMT R are located at the downside of the Power Boards
            • Cornito
              • Jan 2024
              • 90
              • France
              Thank you all for the advice.
              Combining the advice received, the potential root cause may be a faulty resistor in the protection circuit. This is linked to pin 3 according to the TDS.
              Davi.p, the 400V appears very briefly when the backlight starts before being shut down.
              I'll check the resitor values and let you know.
                • 12081
                • U.S.
                Did you test the new leds before and after installation, sometimes they arrive faulty, maybe go back and check over your work. Dirty test for electrolytic caps if no capacitor tester at hand, can use a multimeter set at about 20k ohms, tv UNPLUGGED, reading should gradually rise or fall, switch leads and should go the other way. You will know if you do the test correctly by the readings, can try it on a good cap that isn't installed also.
                • Davi.p
                  • Sep 2009
                  • 4270
                  • Italy - Milan
                  400v does not exist in a circuit without PFC.. check your tester...
                  • Cornito
                    • Jan 2024
                    • 90
                    • France
                    Back on this story, I found for 12$ a PSU on Aliexpress, I bought it and it works.
                    Unfortunately it's not exactly the same as mine, a compatible model anyway, so i'm not able to measure and compare values to find the issue on mine.
                    I'll try with a colleague to check the 2 remaining possible component that may have failed => MOSFET and resistor on control pin.
                    I'll keep you updated
                      • 12081
                      • U.S.
                      Glad to hear it, for 12 dollars vs hours of troubleshooting, I'll spend the 12 dollars every time.
                      • Caimano
                        Asus P2520L starts and stops ok but no display
                        by Caimano
                        Model Asus P2520L
                        MB P552LA_LJ Rev 2.1 with soldered I3 5010U processor
                        The laptop charges battery and seem to react to power on, power off, reset regularly, but nothing appears on screen or HDMI or VGA monitor.
                        Same behaviour when running on battery only, on mains only or on both.
                        Battery charges fine. RTC battery ok at 3.025V.
                        When powered on the power on led lits, after a short while the HDD led flashes, but no video. All voltages seem present. ALL_SYSTEM_PWRGD is present, BUFF_PLT_RST# goes high. CPU warms up and fan starts and stop from time to time....
                        03-29-2023, 03:05 AM
                      • computerbacon79
                        Dell Inspiron 3480 All in One corrupt Bios issue: reaches Dell logo and stops
                        by computerbacon79
                        The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                        05-06-2025, 06:43 PM
                      • Titus6
                        LG OLE65C1 Stand-By issue
                        by Titus6
                        I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                        However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                        I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                        01-31-2025, 04:01 PM
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        🛠 Original Issue
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • Gibon378
                        Problem with stopping audio and video for no reason
                        by Gibon378
                        PC Specs:
                        • CPU: Ryzen 5 1600
                        • GPU: GTX 1080 Palit JetStream
                        • MOBO: ASRock ab350 PRO4
                        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                        • PSU: XFX 650W (don't remember what model)
                        • OS SSD: ADATA SP920
                        • OS: Windows 10 21H2
                        Problem description:
                        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                        11-19-2022, 09:41 AM
