Logik l32digb20
  • sordids999
    • May 2013
    • 2161
    Logik l32digb20
    Backlight constantly flashing on and off,voltages fluctuating until i disable the invertor board then all voltages stable again
    possible screen failure ?
    thanks
    Re: Logik l32digb20
    BL ON steady? Check voltage across large 450V capacitor(s) on PSU.
    • sordids999
      • May 2013
      • 2161
      Re: Logik l32digb20
      370 volt on the 3 big caps im trying to locate the bl on at present any ideas
        Re: Logik l32digb20
        Green or brown wires going to inverter. One is BLON and the other is DIM.
        370V is a little low; does it drop when flickering?
        • sordids999
          • May 2013
          • 2161
          Re: Logik l32digb20
          370 v constant and the BLON is reading 5.18v
            Re: Logik l32digb20
            24V to inverters OK? Also is that green or brown wire you checked? Note: green-to-chassis and brown-to-chassis.
            • sordids999
              • May 2013
              • 2161
              Re: Logik l32digb20
              The brown is reading 5.18 volts the green is reading 1.33 volts but the 24 volt invertors are jumping from all over the place
                Re: Logik l32digb20
                It can be hard to tell if it is PSU or inverter. In my opinion it's a lot more likely to be PSU, but this isn't always the case.
                What I would suggest is attaching two car headlamps, in series, to the 24V output. If you're short of them, Poundland sell them in packs of two (they're probably rubbish, but they're OK for a 65W load.) This will provide approx 65W load to the PSU, around 1/2 what the inverter draws. If that flickers, the PSU has an issue. You can also try adding a second set providing 130W if it does not flicker. 130W is about right for a fully functioning 32" inverter.
                • sordids999
                  • May 2013
                  • 2161
                  Re: Logik l32digb20
                  I had a spare invertor tried that still the same so possible psu fault
                    Re: Logik l32digb20
                    The 370V PFC sounds low to me, if I were to focus on any particular area. Does that rise with the inverter disconnected?
                    • flocko
                      • Nov 2012
                      • 1121
                      Re: Logik l32digb20
                      Hi i have just repaired one of these this week the BLon comes out of the bottom of the Av board to the inverter. This set would not turn the backlight on and would not turn off to standby with side buttons or remote it was the 3.3 v regulator on the Av board in the bottom left corner second one up easy fix
                      • sordids999
                        • May 2013
                        • 2161
                        Re: Logik l32digb20
                        @tom no inverter disconnected still 370 volts
                        @ flocko mines different the side buttons and remote work fine on mine
                        • flocko
                          • Nov 2012
                          • 1121
                          Re: Logik l32digb20
                          still check this regulator, i was told this one had flashing backlight then it failed to come on one day?
                          • sordids999
                            • May 2013
                            • 2161
                            Re: Logik l32digb20
                            do you mean this in the picture ive added and whats the best way to test it
                            • sordids999
                              • May 2013
                              • 2161
                              Re: Logik l32digb20
                              opps sorry forgot to add the picture
                              • flocko
                                • Nov 2012
                                • 1121
                                Re: Logik l32digb20
                                No not that one the one above marked 1117 33 you need to check for 3.3v on the center leg or the tab (north)i would check all the regulators as they seem to feed each other,all the rest are adjustable regulators so take a reading of all three legs 1/2/3 with the tab (north)up,reading 1/2/3 from left to right a good reg will read 1.25v higher on leg 2 then leg 1,so if leg 1 reads 1.5v leg 2 should be 2.75v, there are lots on here on how to test regulators just do a search.
                                  Re: Logik l32digb20
                                  Narrow the problem down. If you have steady BLON and DIM, then the main board shouldn't cause the flickering. Note: I forgot to mention to check PSON. It'd be a good idea to check that too.
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    Re: Logik l32digb20
                                    ok measurements in picture attached this tv is really intermittent now the backlight stays on but i can turn the tv On via remote or side button,but when i try to turn it off via remote or side button i have to switch it of via the mains switch
                                      Re: Logik l32digb20
                                      Middle most regulator, was pin #1 jumping around? That reading is odd, comparing to pin #2.
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        Re: Logik l32digb20
                                        now i cant give you that answer because i have just turned the tv back on and im now back to a flashing backlight and all regulator pins are now fluctuating
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • triplefour
                                          ONN 100012588 Has fluctuating Voltage on PSU 12v
                                          by triplefour
                                          Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                          anyway i go to this guys house to look at an ONN 100012588
                                          this is my first time looking at one of these brand of TV's.
                                          TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                          09-14-2022, 07:41 PM
                                        • unimatrix93
                                          Inexive (Vestel) TV constantly blinking after plugging in
                                          by unimatrix93
                                          Hello everyone, I have a constantly blinking Inexive LED TV.
                                          Display is: VES390UNVA-2D-N01
                                          Mainboard: 17MB97​
                                          PSU: 17IPS71
                                          The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help....
                                          03-26-2025, 08:36 AM
                                        • beetle1303
                                          Wine Chiller - SMPS issue - fluctuating voltages
                                          by beetle1303
                                          My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                          Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                          Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                          Checking further on the primary side: Incoming line input to bridge...
                                          09-04-2023, 10:33 AM
                                        • AlexVG
                                          IPAD A1673 power constantly resetting
                                          by AlexVG
                                          Hello. I came across with the power supply constantly resetting on IPAD A1673.
                                          (I connect it to USB power)
                                          PMU U8100 is rising all voltages except PP3V3_S2 . Consequently, the SYS_ALIVE is also absent.
                                          I have two identical boards with the same symptoms, and I think this is a common problem.
                                          I also have a working board. I've taken all the measurements to compare and haven't seen any abnormalities. There are no signs of a short circuit or water damage.
                                          VREF, IREF are also present.
                                          I also couldn't find any PP3V3_S2 enable signals.
                                          Please help me and suggest...
                                          09-24-2025, 05:24 PM
