SAMSUNG UE48JU6470U Red light flash loop
  • mrhaman
    • Jun 2024
    • Morocco
  • Takeatry
    Yet another Samsung QLED Boot Loop
    by Takeatry
    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
    10-04-2024, 02:57 PM
    09-07-2024, 05:50 AM
  • Deeloc
    How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
    by Deeloc
    I have a 1tb WALRAM SSD (Photo)
    Controller SM2259XT2G (photo)
    Samsung memory (photo):
    Part Number K9DVGB8J1B DCK0
    Name V-NAND V6
    Type TLC
    The SSD itself is detected as 1gb, but is not initialized.
    There is a Sata to USB adapter
    A lot of SMI MPTool, did not flash it. compare flash fail (17)
    K9DVGB8J1B is not listed anywhere
    What to flash?​...
    06-05-2024, 08:32 AM
  • Kaar3l
    Samsung QLED QE65Q7FNAT only standby light
    by Kaar3l
    TV: Samsung QLED QE65Q7FNAT
    PSU: BN4400940A
    MB: BN94-12832K
    I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
    09-24-2024, 01:35 PM
  • marcinq
    Samsung UE60KS7000 No Standby Light
    by marcinq
    I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
    I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
    05-26-2025, 11:36 AM
