Samsung LN52B550 LCD - Horizontal Bar
  • Chris24
    • Feb 2014
    • 42
    Hey everyone,
    While I wait for the new Tcon on my own TV, I was looking at picking this one up locally. Have researched the forums to get an idea of what it could be, and narrowing it down to a tab bonding issue or Tcon. Will be looking at it this afternoon, owner also states the bottom 6 inches "is delayed".
    What are your thoughts?
    Re: Samsung LN52B550 LCD - Horizontal Bar
    Defective panel, avoid
    • Chris24
      • Feb 2014
      • 42
      Thanks for the quick reply Tom and your advice on the forums, I'll pass on it.
      • Chris24
        • Feb 2014
        • 42
        Quick question for you Tom- or anyone else: how did you know it was a bad panel and perhaps where could you point me to identify bad panel symptoms easier?
        New to the forum and have poured over the guides and posts, just trying to learn more- thanks.
        Side note- after I passed on the set the seller told me they had a tech look at it and he said the panel was bad.
          99% of the time, a regional defect on an LCD screen is the panel. (Regional: only part of the screen affected, without obvious repeating pattern or markings.) I have a Toshiba 37" here with the same fault unfortunately, and it's not fixable. We can apply a little pressure to it to try and get it working briefly, but it fails shortly afterwards.
            09-07-2024, 05:50 AM
          • kotel studios
            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
            by kotel studios
            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
            08-06-2025, 02:07 AM
          • rstrube
            ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
            by rstrube
            Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
            Hi Everyone,
            I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
            11-23-2025, 01:37 PM
          • rstrube
            by rstrube
            Hi Everyone,
            Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
            11-23-2025, 12:19 PM
            09-06-2024, 11:40 PM
