UN55d6050
  • gsxr02
    • Feb 2014
    • 7
    UN55d6050
    Hi to all!
    I need a ps board for a UN55d6050 and I got a friend with a brand new un55d6000 in the box with a broken screen, both set have the same parts?
    Thanks for the help, my tv has a stanby light blinking, I check the standby 5vdc constant, but the other vdc are in and out,
    Thanks for any respond!
  • sordids999
    • May 2013
    • 2160
    • uk
    Re: UN55d6050
    You will have to compare part numbers on each board to see if they match up
    • mmartell
      • Oct 2013
      • 3189
      Re: UN55d6050
      Pull the cable attaching the main board to the power supply. Plug the set in. Do the back lights come on ? If not suspect the power supply or back lights. If so, suspect main board.
      Let us know what happens.
      • gsxr02
        • Feb 2014
        • 7
        Re: UN55d6050
        Thanks to all for the fast respond, ps is bad because it is burning the main fuse, I will try to repair it or other a new ps, also I read about the bad open leds, the led that post mmartell has 4 legs how do I test them?
        • mmartell
          • Oct 2013
          • 3189
          Re: UN55d6050
          The legs are in pairs, each side are connected together so you only need to connect across the led, doesn't matter which legs.
          • gsxr02
            • Feb 2014
            • 7
            Re: UN55d6050
            Thanks!
            • mmartell
              • Oct 2013
              • 3189
              Re: UN55d6050
              The bad led's you had, were they on the bottom half of the left hand strip by any chance ?
              • tvtanner
                tvtanner
                • Feb 2014
                • 70
                • usa
                Re: UN55d6050
                Hi- I also have same model no. back light will not light up and also set will not turn on. I changed power supply first and then main panel. still wont come but light keeps blinking like its trying too. can anyone help?
                • tvtanner
                  tvtanner
                  • Feb 2014
                  • 70
                  • usa
                  Re: UN55d6050
                  • tvtanner
                    tvtanner
                    • Feb 2014
                    • 70
                    • usa
                    Re: UN55d6050
                    I think I posted twice. first mistake already. Im sorry. I have two power supplys for this model. If I can get set fixed I will have extra p.s.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Re: UN55d6050
                      If you replaced your main and power supply with know good boards then you have one or more open led's in your backlight strings.
                      You must remove the panel to get to the led's at which point you can test them individually with a DMM in diode mode.
                      • tvtanner
                        tvtanner
                        • Feb 2014
                        • 70
                        • usa
                        Re: UN55d6050
                        thanks for the info. I was afraid of that. wish me luck.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Re: UN55d6050
                          I wouldn't exclude bad panel also.
                          Try removing one ribbon cable(from T_con to panel) at a time, and see if it turns on that way.
                          • tvtanner
                            tvtanner
                            • Feb 2014
                            • 70
                            • usa
                            Re: UN55d6050
                            I made one last check before trying to get to leds. I inserted ammeter in-line with voltage input to leds and then turned set on watched meter and there was no activity at all so I assumed I have bad led circuit. I had hard time getting screws out. I had to use drill on some of them. I discovered there was 95 leds on each side. I assume they are in series. They appear to be mounted on long circuit board. I haven't finished checking all of them but I did find that some of them was dimmer than others. I'm learning as I go along. First time looking inside screen. Does anyone know if those led strips are available? More later.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Re: UN55d6050
                              I couldn't find these strips available - I think for the most part once the boards are stripped from most broken screen tv's the rest goes in the landfill. The good news is at the alarming rate these things fail good ones might start hitting the market.
                              Are you sure they're are not 100 per side ? If iit's anything like mine they are broken in to groups which are run in parallel with each other.
                              I'm still waiting on thermal glue. Going to try and replace my bad leds with good ones.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Re: UN55d6050
                                The one I stripped had 100 per side as well. They were broken into groups of 25.
                                • tvtanner
                                  tvtanner
                                  • Feb 2014
                                  • 70
                                  • usa
                                  Re: UN55d6050
                                  Just got through removing one of strips on side and recounted and I had 99 with one empty spot. No grouping all in one row. Part no.--2011SVS55-FHD-5K6K RIGHT---The other side says left. Same number I guess. I found around 4 bad on each side and a lot look like burned out light bulb. Poor designed if you ask me. Just think you have to replace 600.00 tv because of 2.00 diode. These all mounted in series one goes all go out. Everyone that bought one of these flat screens needs to demand refund.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Re: UN55d6050
                                    How many wires going to each strip ?
                                    • tvtanner
                                      tvtanner
                                      • Feb 2014
                                      • 70
                                      • usa
                                      Re: UN55d6050
                                      There are two wires to each strip. On ckt.board two wires are jumped together which puts them in series
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Re: UN55d6050
                                        You'll likely find the top and bottom half of each strip are run parallel with each other. That means for you to have no backlight you would have to have at least one open led on each of the top and bottom half of at least one side.
