Pioneer PN50951-22U Backlight On, No Image
  • Diah
    • Feb 2013
    • 6360
    yours MB build in ONE Soc if the Soc section GPIO " General-purpose Input/Output "faced issue by BGA at contact pins or the section self defect at Soc . to narrow the issue... disconnect the LVDS from T-CON side and fed t-con at the point 12V_in with 12V from PSU
    • x_orange90_x
      • May 2015
      • 709
      Thanks for the reply!
      Do you mean use a wire to borrow 12v from the psu and apply it to the 12v of the TCON? What would I be looking for after I do this?
      • x_orange90_x
        • May 2015
        • 709
        I took a whole bunch of measurements, none of which are VGH, VGL, VCOM, AVDD.. Because those appear to be absent from this set? A pic of the readings are attached. The last six are the left side and the rest are for the right.
        • Diah
          • Feb 2013
          • 6360
          yes. you will have probably RGB test pattern on the LCD
          • x_orange90_x
            • May 2015
            • 709
            I got around to trying this today. I did not get any sort of pattern to display. However, after reconnecting the lvds cable and turning it on it showed a clear image. Got the Toshiba logo, Fire TV logo and eventually to the initial setup screen. I don't have a remote to proceed, but I did power cycle it a few times and it booted up perfectly each time.
            I removed and reconnected all of the ribbons and cables previously with no affect. Not sure what made the difference this time, but it's working! I'll report back after I get a remote and play around with it for a while.
            Thanks for the help guys!
            • lotas
              • Jan 2016
              • 4575
              • Russia
              #26
              It’s strange, the TV is Pioneer, but the logo was shown by Toshiba, not the original motherboard?
              • x_orange90_x
                • May 2015
                • 709
                Originally posted by lotas
                It's strange, the TV is Pioneer, but the logo was shown by Toshiba, not the original motherboard?
                Oops, I apologize. I meant Pioneer logo. I was working on a Toshiba a couple nights ago!
                Nice catch 😆
                • Diah
                  • Feb 2013
                  • 6360
                  this mean the firmware on T-CON was disrupted, or the IC play crazy.. after disconnect LVDS and fed the t-con with 12VCC drive it to reset.
                  • x_orange90_x
                    • May 2015
                    • 709
                    Click image for larger version  Name:	PXL_20240602_024528515.MP.jpg Views:	0 Size:	491.6 KB ID:	3286654
                    I was kinda thinking it may have done some sort of reset. Thanks for the suggestion!
                    • x_orange90_x
                      • May 2015
                      • 709
                      I ordered a control and received it yesterday hoping to complete the setup and start testing the TV. The control I bought is IR only so when I get to the part in setup for pairing a remote I can't pair it. Without a Bluetooth remote this tv cannot do anything after it is factory reset. After setup is completed apparently an IR remote will work fine 🤦
                      I ordered another one with Bluetooth that should come tomorrow. I will test it out and report back. As this appears to have been a firmware bug of some sort I hope it doesn't resurface again.
                      • x_orange90_x
                        • May 2015
                        • 709
                        Received the new remote and it paired with the tv. I finished setup and tested it out online and with HDMI last night and it appears to work fine. It even updated twice.
                        • jason123
                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                          by jason123
                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                          07-19-2025, 08:07 AM
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • x_orange90_x
                          TCL 50S535 bad tcon or panel issue?
                          by x_orange90_x
                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                          03-29-2025, 11:02 PM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • MDY94
                          Hitachi 50HK6100U display issue
                          by MDY94
                          I own a Hitachi 50HK6100U with a display fault. After some troubleshooting, I've found that removing one tcon cable produces a clear image on the side still connected. Removing the other tcon still provides display output; however, this is a heavily distorted image. With both cables connected, only the top ~25% of the screen provides display output which is still distorted. It's only when both are connected that most of the screen no longer provides output. The attached images show the screen with each tcon cable disconnected, and one with both connected. The red line shows where the display cuts...
                          12-18-2024, 12:31 PM
