Hi all, I got this samsung 40 inch lcd and its got no power coming from the power board, I tested the 5V_STB pin and it read 0v with power cord connected, I had a look about the board and found one of the fuses had blown, I tried replacing the fuse with one the same value but it blew straight away, Would anyone know if i could repair this on a component level, I have all the equipment and am ok with a soldering iron just don't know how to go about diagnosing the exact fault, I've included a few pics that might be usefull, Can see any other visable damage on the board apart from the fuse,
LE40A336J1DXXU No Power
Re: LE40A336J1DXXU No Power
1st thing you want to do is an in circuit test of the bridge rectifier marked BD801S ON THE PCB BOARD.
you will see on the bridge markings of -~~+
you want to test - to ~ you should have reading ONE way only,when reversing meter probes, with dmm set to 200ohm ,and power OFF AND UNPLUGGED FROM THE WALL OUTLET.
~ to ~ you should have no reading either way
~ to + should show reading one way
do these readings and report back what you findLast edited by multimeter; 02-15-2014, 10:28 AM.fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully! -
and the part number of ICM802....fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Comment
Ok so with the bridge rectifier still soldered in the board and powered off i tested with multi meter set to 200 ohms and didn't get any readings, then switched to 2k ohms and got a reading of .569 one way from ~ to - and a reading one way of .572 from ~ to +
Might be worth mentioning though that my multi meter is a cheap crappy one from china but its done the job for me just fine for thepast 6 months or more, ;-)Comment
what that part number of the ic ?fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
Schematic for reference:
http://www.tgohome.com/ServiceManual...&Search=SubmitPlease do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
nice one tom.
check pins 7 and 8, 200 ohm setting this is VCC and GROUND what reading do you get? datasheet hereLast edited by multimeter; 02-15-2014, 11:36 AM.fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
what reading do you get when shorting the probes together?on 200ohm range?fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
note: on many meters 2000 ohm and diode test are the same.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok so i have 2 of the exact same multi meters, when both are set to 200 ohms and i short probes i get i reading of 01.2 and on the other a reading of 00.6, Maybe you could suggest a good multi meter i should invest in, ;-)Comment
the fuse is obviously blowing due to a short,id suggest taking an ohm reading across the fuse clips and record that reading,you have a couple of heatsinks around that fuse and what looks like the stb transformer.
try removing the transistors/diodes one at a time on those heatsinks and recheck resistance across fuse holder ,if you find it goes really high resistance after removing one ,its quite likley thats the culprit.
then test the transisitors/diodes on those sinks for shorts,better results when they are removed also as you wont be picking up random resistance from anywhere else.the atlas dca tester is absolutley brilliant for doing this,it cuts the guesswork out.fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
What resistance do you get measuring at the two legs of the main filter (450vdc CAPS laying side way)?
BTW, there are 2 fuses, one is the main AC fuse, the second is the fuse for the B+ PFC out put, so which one is blown?Last edited by budm; 02-16-2014, 04:36 PM.Never stop learning
Sorry only gettin back to ya now mate, I cant get a reading due to this crappy meter, I've bought an atlas dca55 and a fluke 87 so waiting on those to arrive to do further test, But i have also found a second board the same model in my scrap board pile with what appears to be a different fault, Is there any parts i could swap from either board to repair one of them, I don't know where to start.. :-oComment
If you mean the top board, if that's the only fault, clean off the carbonisation and replace the blue cap.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Bought the dca atlas55, The fluke 87 is 100 quid used and the price new is a bit much, What would be a good multi meter to buy for around 100 new? So many to choose from so wanna make sure i get one that'll do everything i need,Comment
If you really want to repair your TV and willing to shell out 100 quids i would suggest you to once visit jestine yongs site.. just google this name.
Visit his site/blog to look into some really nice repair articles with step by step photos..
If possible purchase his books which are not so expensive..
No need to buy any fancy mulimeters or such expensive equipments.
I m sure you wont regret it..
I m in no way doing any promotions here..
I m a regular visitor of his site & learnt a lot about smps repair..Comment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
