I'm trying to diagnose this TV with a BP2.2U chassis.
Service manual is attached.
My symptoms on it are that it powers on with an almost completley dark screen and after a few seconds it starts flashing on certain areas, mostly towards the left with a very dark purple image and a few vertical lines. I see what looks like static in the brief moments where the screen flashes and the side controls seem to have no effect. There is also no sound. Disconnecting Y and Z boards did not make sound re-appear as suggested by this guide https://www.badcaps.net/forum/showpo...42&postcount=4
Fuses are not blown in either the Y or Z boards.
The alarm LED on the power supply (the one on a small vertically mounted board) stays on throughout the duration of the power being on.
There is a blinking LED on the upper right hand corner of the logic board. The one located below the small signal board.
The power supply makes a noise that sounds somewhat like a fridge running, it's not very loud or anything but it's the best way I can describe it and I also notice it goes along someone to the rythim of the blinking LED on the logic board. it's aso comparable to the sound of a CRT TVs vertical stage oscillating except like I said the sound fluctuates to the rythim of the blinking LED on the logic board.
The ambi lights arent coming on despite their being voltage at their tap on the power supply, however I'm not sure if they're activated.
I measured all the voltages coming out of the power supply and a lot of them seem to fluctuate quite a bit, in some cases up to 2 volts which I wouldnt expect from a switching power supply. The only one that i got that was really stable, only fluctuating about 0.2V was Vscan. Voltages arent quite dead on to what they're supposed to be but are tolerable. I'll post them below.
The only one that seemed way out of whack is "Vtun" at 102 volts when it's apparently supposed to be 33V.
I'm comparing voltages to the ones on page 65 of the philips training guide also attached below.
Vs 204V
Vscan -190V
Ve 82V
Vset 190V
Va 68V
Vg 14V
D5V 5.1V
D3v3 3.38
8V6 8V
+VSND 19.7
-VSND -19.8
5V_SW 5V
12V 11.9B
12VL 12V
Vtun 102V
5V2 5V
Again as I said there's fluctuation on a lot of the voltages and it seems to go along with the noise of the power supply and the blinking LED on the logic board.
Any help with this would be much appreciated.
Vs 204V
Vscan -190V
Ve 82V
Vset 190V
Va 68V
Vg 14V
D5V 5.1V
D3v3 3.38
8V6 8V
+VSND 19.7
-VSND -19.8
5V_SW 5V
12V 11.9B
12VL 12V
Vtun 102V
5V2 5V
