Samsung UE55H8000SZ with TCON BN41-02112A
  • michdundee
    replied
    Originally posted by SergioSilva2024
    Hi michdundee,
    Could you tell me where you find a brand new T-CON (BN41-02112A) nowadays?
    Hi Sergio, ebay in Europe or samsung parts store in Europe.
  • SergioSilva2024
    replied
    Originally posted by michdundee
    Hi all, thank you for the support given up to this point. I have received today a brand new T-CON and the TV has started to work again.
    Hi michdundee,
  • michdundee
    replied
  • Diah
    replied
    Diah no red light on the optic audio port
    before 4-5 years i faced this with sansung curve,,, it was 55 too.... it had U ribbon on the panel buffer boards when i disconnect one right side it come on with 3/4 picture,,,, there was broken on glass corner end the down layer of Panel pcb 2 lines was broken
  • michdundee
    replied
    Originally posted by Diah
    okay,,, then what about the optic audio port... did it lit red or not.
  • Diah
    replied
    Hi Diah as already described the backlight is up and running without issues. All backlights are on but I cannot see picture or hear sound
  • michdundee
    replied
    when no data send from the main boards to T-CON... then LED 3 will be off.
    you have the only blinking status led red.. MB didn't start at all, BLU pin 12 are high as usual, when you plug the tv in wall you never saw the BL turn on.... unless you unplug MB from PSU... correct ??
    if this what i wrote the case... you need to take the panel out a part and start inspect test the BL manually one by one ..
    if you unplug the panel from T-CON MB should start BL come one... and you can hear sound.... but at yours case this didn't happened because there are error before the Tv start.
  • Diah
    replied
  • michdundee
    replied
    Originally posted by lotas
    I can't say now, but 90 percent of the faulty panel 3 led is responsible for the supply voltage of the panel, if the panel is not working properly, then when you turn on the 3 led flashes and immediately goes out and the output voltage from the t-con to the panel is blocked.
    LED1 (presence of 12V input)
    LED2 (secondary power supply of the processor and RAM of the t-con itself)
    LED3(matrix power supply Von, AVDD, Voff..)​
    Since I have no sounds too could it be instead it is a mainboard issue maybe not able to boot properly? I have checked mainboard supplies and they seem ok. in case of panel issue can it be fixed?
  • lotas
    replied
    lotas do you suspect already something? one of the 2 panels issue? I'm slow on providing info about the test you have suggested since I'm ordering a connector on the T-CON that is not perfect. I have ordered a new T-CON too.
  • michdundee
    replied
  • michdundee
    replied
    lotas Diah I appreciate all the helps given here so I will follow every request coming from everybody. everybody is bringing hisown experience and I appriciate it.
    Diah pin 12 is BLU_ON = 4.81V --> I think that is correct saying that the backlight unit is working correctly (as already anticipated by lotas )
  • lotas
    replied
    You don't need to tell me what to do. And you don't need to prove that you are smarter than others.​
  • Diah
    replied
    If there were problems with the power supply, then the backlight would not work and 1 LED (12v is the norm) on the T-con would not light up.
    you still didnt get what i have on my head--- keep out please .. my searching not on shit t-con... i am inspecting why always red blinking and PS on and 13V we have.
  • Diah
    replied
    lotas please don't comment at any request... you have your own way and other have their too... .
    @michdundee please tell me what written on pin 12 its not clear and the reading of V could be error
  • lotas
    replied
  • michdundee
    replied
    Why do you need these voltages now, your 3 LED on the t-con is not lit, put a jumper and check your panel by disconnecting different cables.
    I will do it in the next days thank you. I will let you know the outcome of the test.
    Diah was asking the table above and I have provided the list with related values.
  • lotas
    replied
    see attached picture too
    2 3.26V 1 0V
    4 3.26V 3 3.25V
    6 3.26V 5 0V
    8 3.07V 7 12.83V
    10 3.16V 9 12.83V
    12 4.81V 11 12.83V
    14 3.3V 13 12.83V
    16 0V 15 12.83V
    18 0V 17 0V
    20 12.83V 19 12.83V
    22 0V 21 12.83V
  • michdundee
    replied
    yes its ok, but what about other V the PSU generated... list them over here with pin name
    2 3.26V 1 0V
    4 3.26V 3 3.25V
    6 3.26V 5 0V
    8 3.07V 7 12.83V
    10 3.16V 9 12.83V
    12 4.81V 11 12.83V
    14 3.3V 13 12.83V
    16 0V 15 12.83V
    18 0V 17 0V
    20 12.83V 19 12.83V
    22 0V 21 12.83V
  • Diah
    replied
    Hi Diah, I have a stable 3.3V on PS_ON. is that ok?
    09-07-2024, 05:50 AM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
    Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
    This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 06:20 PM
