Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
  • timonix20
    • Aug 2019
    • 3
    • France
    hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
    the TV starts, LG logo, then nothing (rear backlight)
    no reaction to rear command or infrared
    the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
    I have a chance with a usb procedure or other if you have .bin
    if any people have this main board
    thank you
  • Diah
    • Feb 2013
    • 6371
    there are Russian web portal they have good sources of all web os ( engineering firmware ), for many years i posted here over LG threats but still i cant find it... it will recover yours TV
    edit: here you are
    to use USB you need to make folder name LG_DTV and put the firmware inside... while it on insert the usb stick hope yours screen will show you dialoge
    • lotas
      • Jan 2016
      • 4598
      • Russia
      You are right in thinking that the problem is either in the eMMC or in the processor.
      • Diah
        • Feb 2013
        • 6371
        only stupid people whom judge on eMMC or SOC at LG plat forum before starting from webos.firmware... or casting the start log via UART
        • lotas
          • Jan 2016
          • 4598
          • Russia
          I'll see how he restores this LD33B\LC33B\LE33B chassis using usb...
          • Diah
            • Feb 2013
            • 6371
            please don't challenge me with LG WEBOS PLATFORM OR LINUX: ..... thx
            • lotas
              • Jan 2016
              • 4598
              • Russia
              Over 10 years, eMMC has lost 90 - 100% of its memory lifetime.
              • Diah
                • Feb 2013
                • 6371
                this is childish thinking... LG TVs 3D from years production 2012 atilt working even LED's never changed.
                • lotas
                  • Jan 2016
                  • 4598
                  • Russia
                  Childish thinking is when people think that eMMCs are forever and have no wear and tear. Type in the search what “eMMC lifetime” is and you will find out a lot of interesting things; if you have never encountered eMMC, then you are probably lucky.
                  • timonix20
                    • Aug 2019
                    • 3
                    • France
                    Hello, I tried the general public LG flash procedure a while ago, it doesn't trigger the flash for me.
                    Thank you if people have .bin or other way .
                    • timonix20
                      • Aug 2019
                      • 3
                      • France
                      • lotas
                        • Jan 2016
                        • 4598
                        • Russia
                        And you hoped that this would work, if the problem is with the eMMC, then only replace it with the already programmed one.
                        • Diah
                          • Feb 2013
                          • 6371
                          we do know life time on solid sector.... but could you explain please why for example plasma LG / Samsung / Sony still working and their eMMC didn't die or life time ended.... of sure the users had many time update or new search or whatever write on the sectors ???
                          • lotas
                            • Jan 2016
                            • 4598
                            • Russia
                            In plasmas they usually installed Nand memory, in old LCDs they began to install eMMC of small volume 4-8Gb and the memory was filled almost to capacity, and rewriting became more frequent (eMMC is a nand flash + built-in controller (two in one), which contains its own firmware and now this controller monitors the health of nand memory; when its health ends, the controller blocks access to memory).
                            • Diah
                              • Feb 2013
                              • 6371
                              eMMC contain NAND too .. only emmc don't have erase function.
                              Architect
ID:	3259666 Click image for larger version
                              • Diah
                                • Feb 2013
                                • 6371
                                • lotas
                                  • Jan 2016
                                  • 4598
                                  • Russia
                                  I wrote about this above. "(eMMC is a nand flash + built-in controller (two in one)"
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4326
                                    • Italy - Milan
                                    The board can have bga soldering issue or both data fail and bga issue for me, so for the common humans a replacement board is the only way to run, the best way is reballing+kindly rom writing, when the first is the less problematic, the second needs a good donor board or friend tech.. which way do you prefer?
                                    • saghi88
                                      i need eMMC Dump for Sony KDL-55W805C
                                      by saghi88
                                      The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
                                      This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
                                      does anyone have the EMMC dump file?
                                      Model: Sony KDL-55W805C
                                      Mainboard: 1-980-805-31
                                      EMMC: SK HYNIX H26M52103FMR
                                      Display-Panel: T550HVF06.0
                                      07-04-2025, 02:11 PM
                                    • Morosan Dimitrie
                                      Sony KDL 55W-955B Sony EMMC dump search :)
                                      by Morosan Dimitrie
                                      Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
                                      KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,...
                                      06-08-2024, 04:13 PM
                                    • ducky29
                                      About emmc replacement
                                      by ducky29
                                      Hello. After lots and lots of tvs having firmware failure I decided to get a socket to reprogram the emmc. Yesterday I checked that one emmc had a 100% usage so it couldn't be reprogrammed and it should be replaced.
                                      I checked in my store and I had no exact replacements for this emmc (KLM8G1WEMB-B031).
                                      Is it possible to replace even if the part numbers do not match as long as the emmc has the same capacity?
                                      Is there any anywhere where I can order new emmc. I checked few stores in Aliexpress but I think they are used or is it safe to order emmcs from...
                                      06-24-2023, 04:45 PM
                                    • joby91
                                      SONY KD-55AF9 OLED MAIN-BM3-1-983-356-11 EMMC Firmware
                                      by joby91
                                      I have SONY KD-55AF9. Mainboard MAIN-BM3-1-983-356-11 with defekt EMMC.
                                      I wanted to buy new EMMC and Flash the firmaware on it. Does anyone have the firmware for this TV. I would be really grateful.
                                      I found one chat about firmware on ************** forum but i cannot read the comments.
                                      https://**************/forum/108-114100-1#880537
                                      09-04-2024, 01:34 PM
                                    • lti
                                      Sony MDR-IF245R transmitter LED replacement
                                      by lti
                                      I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
                                      06-28-2024, 01:47 PM
