Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
  • timonix20
    • Aug 2019
    • 3
    • France
    hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
    the TV starts, LG logo, then nothing (rear backlight)
    no reaction to rear command or infrared
    the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
    I have a chance with a usb procedure or other if you have .bin
    if any people have this main board
    thank you
  • Diah
    • Feb 2013
    • 6504
    there are Russian web portal they have good sources of all web os ( engineering firmware ), for many years i posted here over LG threats but still i cant find it... it will recover yours TV
    edit: here you are
    to use USB you need to make folder name LG_DTV and put the firmware inside... while it on insert the usb stick hope yours screen will show you dialoge
    • lotas
      • Jan 2016
      • 4818
      • Russia
      You are right in thinking that the problem is either in the eMMC or in the processor.
      • Diah
        • Feb 2013
        • 6504
        only stupid people whom judge on eMMC or SOC at LG plat forum before starting from webos.firmware... or casting the start log via UART
        • lotas
          • Jan 2016
          • 4818
          • Russia
          I'll see how he restores this LD33B\LC33B\LE33B chassis using usb...
          • Diah
            • Feb 2013
            • 6504
            please don't challenge me with LG WEBOS PLATFORM OR LINUX: ..... thx
            • lotas
              • Jan 2016
              • 4818
              • Russia
              Over 10 years, eMMC has lost 90 - 100% of its memory lifetime.
              • Diah
                • Feb 2013
                • 6504
                this is childish thinking... LG TVs 3D from years production 2012 atilt working even LED's never changed.
                • lotas
                  • Jan 2016
                  • 4818
                  • Russia
                  Childish thinking is when people think that eMMCs are forever and have no wear and tear. Type in the search what “eMMC lifetime” is and you will find out a lot of interesting things; if you have never encountered eMMC, then you are probably lucky.
                  • timonix20
                    • Aug 2019
                    • 3
                    • France
                    Hello, I tried the general public LG flash procedure a while ago, it doesn't trigger the flash for me.
                    Thank you if people have .bin or other way .
                    • timonix20
                      • Aug 2019
                      • 3
                      • France
                      • lotas
                        • Jan 2016
                        • 4818
                        • Russia
                        And you hoped that this would work, if the problem is with the eMMC, then only replace it with the already programmed one.
                        • Diah
                          • Feb 2013
                          • 6504
                          we do know life time on solid sector.... but could you explain please why for example plasma LG / Samsung / Sony still working and their eMMC didn't die or life time ended.... of sure the users had many time update or new search or whatever write on the sectors ???
                          • lotas
                            • Jan 2016
                            • 4818
                            • Russia
                            In plasmas they usually installed Nand memory, in old LCDs they began to install eMMC of small volume 4-8Gb and the memory was filled almost to capacity, and rewriting became more frequent (eMMC is a nand flash + built-in controller (two in one), which contains its own firmware and now this controller monitors the health of nand memory; when its health ends, the controller blocks access to memory).
                            • Diah
                              • Feb 2013
                              • 6504
                              eMMC contain NAND too .. only emmc don't have erase function.
                              Architect
ID:	3259666 Click image for larger version
                              • Diah
                                • Feb 2013
                                • 6504
                                • lotas
                                  • Jan 2016
                                  • 4818
                                  • Russia
                                  I wrote about this above. "(eMMC is a nand flash + built-in controller (two in one)"
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4521
                                    • Italy - Milan
                                    The board can have bga soldering issue or both data fail and bga issue for me, so for the common humans a replacement board is the only way to run, the best way is reballing+kindly rom writing, when the first is the less problematic, the second needs a good donor board or friend tech.. which way do you prefer?
                                    • EazyBone
                                      Sony 55/65 A1E sony OLEDs EMMC dumps
                                      by EazyBone
                                      Does anyone know where one would get these dumps for EMMC? I have two 55/65 A1E sony OLEDs that likely need new EMMC chips but I do not have the file.
                                      Is there a database or website you use to find these?
                                      lotas anything in the Russian space websites you know of also?
                                      10-31-2025, 06:22 PM
                                    • saghi88
                                      i need eMMC Dump for Sony KDL-55W805C
                                      by saghi88
                                      The TV won't turn on (no power, no LED,). All voltages are present on the motherboard. The CPU is working and is getting warm.
                                      This is a common issue with this model. If the eMMC is faulty, the TV will either go into a reboot loop or not turn on at all.
                                      does anyone have the EMMC dump file?
                                      Model: Sony KDL-55W805C
                                      Mainboard: 1-980-805-31
                                      EMMC: SK HYNIX H26M52103FMR
                                      Display-Panel: T550HVF06.0
                                      07-04-2025, 02:11 PM
                                    • mhd bero
                                      Sony KD-65XD8505 EMMC NEED
                                      by mhd bero
                                      Hi.
                                      I'm searching for an eMMC dump for Sony KD-65XD8505
                                      Motherboard: 1-980-832-11
                                      THE TV NO BOOTING HE HAVE 8 TIME RED LED BLINKING I THINK EMMC DUMP FILE IS DAMAGE.
                                      Thank you.
                                      09-09-2025, 09:31 AM
                                    • Morosan Dimitrie
                                      Sony KDL 55W-955B Sony EMMC dump search :)
                                      by Morosan Dimitrie
                                      Hello guys, can someone help me with an eMMC dump for a Sony KDL55W-955B TV, I tried to read the original memory with the RT809H but it shows me that it only has 1888MB even though it should have around 3.8GB. On a new memory it shows me 3776MB. From what I found on the Sony page, the following models could also be compatible:
                                      KDL-65W955B, KDL-55W955B, KDL-60W855B, KDL-50W805B, KDL-42W705B, KDL-32W705B, KDL-48W605B, KDL-40W605B, KDL-60W605B, KDL-55W805B, KDL-42W805B, KDL-48W585B, KDL-32W706B, KDL-42W706B, KDL-42W815B, KDL-42W817B, KDL-50W815B, KDL-55W815B, KDL-42W828B, KDL-42W829B,...
                                      06-08-2024, 04:13 PM
                                    • ducky29
                                      About emmc replacement
                                      by ducky29
                                      Hello. After lots and lots of tvs having firmware failure I decided to get a socket to reprogram the emmc. Yesterday I checked that one emmc had a 100% usage so it couldn't be reprogrammed and it should be replaced.
                                      I checked in my store and I had no exact replacements for this emmc (KLM8G1WEMB-B031).
                                      Is it possible to replace even if the part numbers do not match as long as the emmc has the same capacity?
                                      Is there any anywhere where I can order new emmc. I checked few stores in Aliexpress but I think they are used or is it safe to order emmcs from...
                                      06-24-2023, 04:45 PM
