Guide : Philips OLED TVs how to remove the protection mode NVM.EED
  • Diah
    • Feb 2013
    • 6498
    OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
    not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
    Philips OLED TVs. we can switch the protection code to off via binary.
    - ropy it on empty usb stick and insert it while the tv off at USB 1
    -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the tv.after it finishing from restart... .. it should got out from the protection issue.
  • lotas
    • Jan 2016
    • 4803
    • Russia
    Это относится к шасси TPM19.6E LA. XXPUS6XX4
    • Diah
      • Feb 2013
      • 6498
      NO
      its belong and can apply to these chassis
      Affected Chassis: TPM19.1E LA, TPM19.6E LA, TPM19.1A LA, TPM19.1T LA, TPM20.1E
      OA, TPM20.1A OA, TPM21.1E OA, TPM21.1L OA, TPM21.1A OA​
      • Resistor6k8
        • Sep 2024
        Thanx Diah for your information. Our PHILIPS 77OLED806/12 is working again after endless LED 4x-flashing.
        until then, BEN
        • kozejk555
          • Jan 2025
          • 13
          • czech
          Hi
          I need NVM for 55oled803, can you halp me?
          • Diah
            • Feb 2013
            • 6498
            Originally posted by kozejk555
            Hi
            NVM.bin you can find it here
            TPM171E_2k18_N2O_NVM_v59
            • kozejk555
              • Jan 2025
              • 13
              • czech
              Thank you I find NVM for my TV. I have to rename file?
              • kozejk555
                • Jan 2025
                • 13
                • czech
                So NVM helped temporarily. Now I have an image, and the TV starts to load. However, it always crashes, and the process repeats. When I remove the USB, I lose the image again.
                • Diah
                  • Feb 2013
                  • 6498
                  you wrote NVM and the file i send you are NVM.bin... if you need to remove the protection need NVM.eed
                  firmware Android TV 8 Oreo (TPM171E: 107.1.143.0 as i know it had already the protection disabled .. so downgrade and disable the auto update.
                  search in this archive Firmware from Alex
                  • kozejk555
                    • Jan 2025
                    • 13
                    • czech
                    i downloaded autorun.upg version 107.1.143.0 and the TV won't update. Only PKG files seem to work. I don't know where the problem is. I am also sending the log
                    • Diah
                      • Feb 2013
                      • 6498
                      upgrade_loader.pkg u need you have it on the site.
                      here download and unzip... copy upgrade_loader.pkg on USB formatted FAT32 MBR mode
                      • kozejk555
                        • Jan 2025
                        • 13
                        • czech
                        there is only autorun.upg. I must rename this autorun.upg on uprage_loader..pkg???
                        • Diah
                          • Feb 2013
                          • 6498
                          what are you talking .... the link in post #11 are direct download and when you unzip it you will have upgrade_loader.pkg
                          if you download dont know how,,,, so how you will be able to fix OLED !!!
                          • kozejk555
                            • Jan 2025
                            • 13
                            • czech
                            sorry I´m idiot. I got it
                            • kozejk555
                              • Jan 2025
                              • 13
                              • czech
                              how long does the upgrade process take? It's been running for me for 20 minutes
                              • kozejk555
                                • Jan 2025
                                • 13
                                • czech
                                Bro, my type of tv is TMP18.1ELA your firmware is for TMP17. Do you have for my type?
                                • Diah
                                  • Feb 2013
                                  • 6498
                                  where do you have this false Info... yours 55OLED803 TPM171E from year 2018 , firmware 100% correct.
                                  • lotas
                                    • Jan 2016
                                    • 4803
                                    • Russia
                                    Not everything depends on the region.But their firmware number is TPM171E_xxxxx
                                    • Diah
                                      • Feb 2013
                                      • 6498
                                      exactly.. HW from year 2018.. as i wrote but Firmware still from 2017. so we call it all HW years to its original Firmware TPM171E, even there are HW from 2019 too
                                      • kozejk555
                                        • Jan 2025
                                        • 13
                                        • czech
                                        I have NVM.BIN and TPM171E_107.1.143.0 firmware loaded on usb. If I leave the USB in the TV, the firmware is constantly updated, even for an hour. If I remove the USB, the TV turns off and indicates an error. I don't know how to continue.​
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • djordje
                                          Philips 55 oled 804/12 red light blink
                                          by djordje
                                          Hello all,
                                          I have Philips Oled 55 (804/12) with black screen and red light blink.
                                          I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                          Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                          When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                          My questions is what should i do next...
                                          01-03-2025, 04:00 PM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
