Guide : Philips OLED TVs how to remove the protection mode NVM.EED
    OLED Cells over all OLED brands are easily its drooping more currents will be increase which it trick the SOS signal which T-CON driver boards will send to the Mainboards... the NVM software on the Mainboards will shutdown the PSU..
    not all fault at OLED are bad-- some issue can remain working with minimal issue at displaying generate
    Philips OLED TVs. we can switch the protection code to off via binary.
    - ropy it on empty usb stick and insert it while the tv off at USB 1
    -turn on the Tv it will restart 2 or 3 time then plug out the stick and turn on the tv.after it finishing from restart... .. it should got out from the protection issue.
    Это относится к шасси TPM19.6E LA. XXPUS6XX4
      NO
      its belong and can apply to these chassis
      Affected Chassis: TPM19.1E LA, TPM19.6E LA, TPM19.1A LA, TPM19.1T LA, TPM20.1E
      OA, TPM20.1A OA, TPM21.1E OA, TPM21.1L OA, TPM21.1A OA
        Thanx Diah for your information. Our PHILIPS 77OLED806/12 is working again after endless LED 4x-flashing.
        until then, BEN
          Hi
          I need NVM for 55oled803, can you halp me?
            Originally posted by kozejk555 View Post
            Hi
            NVM.bin you can find it here
            TPM171E_2k18_N2O_NVM_v59
              Thank you I find NVM for my TV. I have to rename file?
                So NVM helped temporarily. Now I have an image, and the TV starts to load. However, it always crashes, and the process repeats. When I remove the USB, I lose the image again.
                  you wrote NVM and the file i send you are NVM.bin... if you need to remove the protection need NVM.eed
                  firmware Android TV 8 Oreo (TPM171E: 107.1.143.0 as i know it had already the protection disabled .. so downgrade and disable the auto update.
                  search in this archive Firmware from Alex
                    i downloaded autorun.upg version 107.1.143.0 and the TV won't update. Only PKG files seem to work. I don't know where the problem is. I am also sending the log
                      upgrade_loader.pkg u need you have it on the site.
                      here download and unzip... copy upgrade_loader.pkg on USB formatted FAT32 MBR mode
                        there is only autorun.upg. I must rename this autorun.upg on uprage_loader..pkg???
                          what are you talking .... the link in post #11 are direct download and when you unzip it you will have upgrade_loader.pkg
                          if you download dont know how,,,, so how you will be able to fix OLED !!!
                            sorry I´m idiot. I got it
                              how long does the upgrade process take? It's been running for me for 20 minutes
                                Bro, my type of tv is TMP18.1ELA your firmware is for TMP17. Do you have for my type?
                                  where do you have this false Info... yours 55OLED803 TPM171E from year 2018 , firmware 100% correct.
                                    Not everything depends on the region.But their firmware number is TPM171E_xxxxx
                                      exactly.. HW from year 2018.. as i wrote but Firmware still from 2017. so we call it all HW years to its original Firmware TPM171E, even there are HW from 2019 too
                                        I have NVM.BIN and TPM171E_107.1.143.0 firmware loaded on usb. If I leave the USB in the TV, the firmware is constantly updated, even for an hour. If I remove the USB, the TV turns off and indicates an error. I don't know how to continue.
