Philips PSU (715G7350-P01-000-002S) behaving funny
  • Diah
    • Feb 2013
    • 6503
    TV show RGB screen 99% LVDS damage. shorts or cut out the sliver pins contact... show us the clear photo of the LVDS both side contact pins.
    LVDS the flat cable between Mainboards and T-CON
    • Montse
      • Feb 2025
      • 15
      • Spain
      #42
      I attach LVDS connectors in both sides, TCON and SSB board. Please let me know if it is clear enough.
      Thanks a lot for your help!
      • Montse
        • Feb 2025
        • 15
        • Spain
        #43
        Where can I buy this cable in case it's wrong? I have seen second hand cables in eBay and new ones without the connectors but new ones with the connectors I need, I cannot find...
        BTW, just as a refresh of mind, my issue started with the PSU, the TV did not do anything at all and after replacing the diode D9105 then I got the issue of the burning/aging mode. I wonder if the PSU is fully correct now. The TV was working for only 5 minuts when it just died.
        I got the service manual of the TV, it is around 25Mb. I think there is a place in this forum where I can share it, isn't it?
        Thanks a lot!
        • Diah
          • Feb 2013
          • 6503
          on this area its look the top pins will exchange place at sockt.. also check whole cable surface if there are black burn points..
          • Montse
            • Feb 2025
            • 15
            • Spain
            #45
            Click image for larger version  Name:	image_374366.jpg Views:	19 Size:	119.3 KB ID:	3577766
            Thanks a lot! I will purchase the cable! Any idea where I can find it? In eBay I have found one that has all same references but it's for 55'' TV and mine is 43 so I guess I would need to fold it in a different way and I am not sure when this may damage the cable...
            The references I can read in the cable are: DEREN-S E241234 AWM 20624 80C 60V VW-1 and then it has the 2 connectors of the pictures above. The TV is a Philips 43PUS6401/12.
            Any help on this, please?
            Thanks a lot in advance!!​
            • Montse
              • Feb 2025
              • 15
              • Spain
              #46
              I have found this cable but without the connectors:
              https://es.aliexpress.com/item/1005004583043404.html?src=google&src=google&albch=shopping&acnt=439-079-4345&slnk=&plac=&mtctp=&albbt=Google_7_shopping&gclsrc=aw.ds&albagn=888888&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=es1005004583043404&ds_e_product_merchant_id=106865871&ds_e_product_country=ES&ds_e_product_language=es&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=22050034252&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gclid=Cj0KCQiA8fW9BhC8ARIsACwHqYr0-WrVPfOmIdDw17IFhsRlXs1jZl1pcWMUsTZvJGIrfobH9gGNdHQaAqcqEALw_wcB&aff_fcid=7a621261a6a74c6f900d091af5fc3d2c-1740490158452-05345-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=7a621261a6a74c6f900d091af5fc3d2c-1740490158452-05345-UneMJZVf&terminal_id=9fe1e1b4269e4f3a976fbb57f3e36900&afSmartRedirect=n&gatewayAdapt=glo2esp
              This looks like mine but longer and second hand:
              https://www.ebay.es/itm/353795651112...Bk9SR_igjtWnZQ
              And this one looks like mine, with connectors and even the folding but the web is in a language I am not able to read:
              https://prom.ua/p2372584702-shlejf-l...aoNetrXGkB2b3k
              I attach the pictures of my cable, in one side it is 20cm and in the other side, not counting the witdh of the other, it's 14,5cm. The cable unfolded is 38cm, 3cm witdh and 51 pins, type A, pins are in the same side.
              • Montse
                • Feb 2025
                • 15
                • Spain
                #47
                Finally I have found it!
                https://es.aliexpress.com/item/10050...yAdapt=glo2esp
                Now I need to be very patience to receive it. I hope that this fixes the issue in the TV and I can use it again.
                Thank you!​
                • Montse
                  • Feb 2025
                  • 15
                  • Spain
                  #48
                  Hi guys! Some news from me!
                  I received the cable and it worked!!! I jumped from happiness!!! Closed the TV and hanged it back to the wall. But then... after some time on, it starts restarting in a loop while the standby led is blinking... so I guess there is still something wrong with the TV. There is no firmware update to be done. I can see Philips logo, then Android starting like after a refresh I think there are 4 balls of different colors, then it goes to the previous status, if I am using the TV with the antena, it goes to the same channel, if I was using FireStick, it goes to the exact same point before the reset. I needed to disconnect from the tension because with the remote control did not switch of. This morning as it is cold (I guess) it works normally again but I guess if I use it longer, I will get the restarting loop again. Any ideas of what this can be now?
                  Thanks a lot for all your help!!
                  • Montse
                    • Feb 2025
                    • 15
                    • Spain
                    #49
                    You are the best!! The chage of cable made a big difference! TV worked again, nevertheless, after 20 minuts working, the sound stops and then the TV starts bootlooping undefined. I guess there should be something wrong still with the hardware, any ideas? In the boot loop I can see Philips logo, then Android, the 4 color balls and it comes back to where I was before the reboot, stays there for few seconds and restarts again. All of this while standby red led is blinking.I would appreciate any suggestion as I am run out of ideas!
                    Thanks a lot!
                    Regards,
                    Montse
                    • Montse
                      • Feb 2025
                      • 15
                      • Spain
                      #50
                      Originally posted by William1967
                      The tv has an so called OPEN CELL panel/t-con, it goes in WBRG mode when there is 12V on the t-con but no data from the mainboard. Check the LVDS cable if there is no damage and check if there is data comming from the mainboard.
                      Any ideas on my current issue? The cable was damaged. I changed it and now it works but after 20 minutes working, the sound stops and TV starts bootlooping undef...
                      • William1967
                        • Nov 2017
                        • 217
                        • Netherlands
                        #51
                        Try to run the upgrade_loader.pkg to reset the EMMC files, if that does not help there are lots of things that can go wrong that can cause a reboot. The EMMC could also be at it's end of life, seen that a lot of times with these mainboards.
                        • u666sa
                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                          by u666sa
                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                          Platform: ipa32 la-m024p rev 1b
                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                          I found a short on the other side:
                          10-04-2025, 05:03 PM
                        • supermattch
                          HP 15dy-2021nr wont power on mystery volts
                          by supermattch
                          Hi everyone.
                          I am diagnosing my personal laptop, because it wont power on and no leds light up.
                          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                          09-23-2025, 12:13 PM
                        • alro7779
                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                          by alro7779
                          Hello, guys!
                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                          09-14-2025, 12:25 AM
                        • G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                          by G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                          It does power up when pressing the power button.
                          I already try the power button while plugin the plug with no result.
                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                          Could this be an PSU or eMMC issue ?
                          07-19-2025, 03:43 AM
                        • MisterAIL
                          PS5 digital / No Power / No Beep / Good power supply
                          by MisterAIL
                          Brought a non functionnal PS5. Apparently only a bad PSU...
                          No beep, nothing.
                          After some tests i found this :
                          - PSU is fine (12 volts stable)
                          - 12 volts line is shorted
                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                          - By the way, nothing change. No signal, no power, no beep.
                          Mesuring all rails with my workbench psu (12 volts input)
                          - 0.00 amp drawing
                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                          03-12-2024, 03:24 PM
