Can I fit a UE49MU6470 Diffuser into a UE49NU7100K?
  • fuus
    • 123
    • England
    Looking again the patch has moved after it's been stood upright for a few days - lets hope it's just water....!
    Final question before re-asssembly - does it matter which way round the perspex sheets are in terms which side of the sheet faces the front? and if so how do I tell which orientation is correct? I have the sheets in the correct order I think
    • bohaboha
      • Nov 2012
      • 973
      • sweden
      The best thing to do is to put them exactly as they were at the time of removal
      Because if you turn them 360 degrees it can have a big effect on light reflectivity that it can get brighter on the upper partโ€‹
      • EazyBone
        • Jun 2023
        • 1314
        • United states
        The correct order matters, I don't think orientation will matter. The diffuser orientation matters.
        Disconnect the main board and plug in the power cord and the LEDs should turn on, then you can flip them up and down while it's plugged in and see for yourself. I would do this anyways after installation of the diffuser because there is always small points that might not be clipped etc and you'll catch any imperfections before you reassemble the whole TV
        • fuus
          • 123
          • England
          I'm going to need to take it back apart to give the diffuser a clean but we have progress!
Name:	20240427_181400 - Copy.jpg
          • EazyBone
            • Jun 2023
            • 1314
            • United states
            You have bright spots in bottom corners, make sure the snap connectors are down enough. That's going to show up on the picture. Those other spots, put the sheets over top lay it flat and turn it on, it hides some of what you see so brightly. Then you'll have a better estimation of what you need to cleanup. Not all of that will show through
            • fuus
              • 123
              • England
              #26
              Thanks again for the fantastic tips. Will give it a go tomorrow and see where we get to. I did this in a rush this afternoon, I think as you say the corners are either not quite snapped in correctly or the weight of the tv sat on it is distorting it. To be continued!
              • EazyBone
                • Jun 2023
                • 1314
                • United states
                #27
                Yes! Everything should look as close as possible to this area here or it's going to show up once you put the tv back together. Like I said put those other 2 sheets on and lay it flat, and put lights on and some of the defects will go away. But definitely not those bright spots
                • fuus
                  • 123
                  • England
                  #28
                  I don't think I will be able to resolve the issue in the bottom left fully as manually applying pressure hasn't changed much - BUT I'm really happy with the result. I'm going to put the panel back on once the capacitors have had 20 minutes to discharge
Name:	20240428_094417 - Copy.jpg
                  • fuus
                    • 123
                    • England
                    #29
                    I am really hoping this is a bit of dust in the connector! Click image for larger version
Name:	20240428_111321 - Copy.jpg
                    • EazyBone
                      • Jun 2023
                      • 1314
                      • United states
                      #30
                      Oh boy ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                      • fuus
                        • 123
                        • England
                        #31
                        No amount of fiddling with the ribbon cable seems to improve it, I think I might have to admit defeat on this occasion. Thanks everyone for your input
                        • EazyBone
                          • Jun 2023
                          • 1314
                          • United states
                          #32
                          Yea, I've had this happen once before, but to be fair the backlight was out so maybe it was already there before changing it. Sorry to see
                          • howardc64
                            A1312 (27โ€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • mrsith
                            Samsung UE49NU7100K melted diffuser
                            by mrsith
                            I have seen some threads that touched this subject, but none of them actually answered the question I have in my mind.
                            I've bought a 'not working' Samsung UE49NU7100K, which turned out to be working but with no backlights. I did not bother to do any PSU measurings as TV itself is working, was pretty sure a single LED has burned out.
                            After disassembling I was surprised to see edge-lit backlight and the diffuser which was cracked and melted in many, many places, almost like every single LED has burned it. Most of the LEDs look burned out by the way, which made...
                            03-24-2021, 12:08 PM
                          • Kemer
                            Graphics Card mounting frame
                            by Kemer
                            Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                            As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                            I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                            What worries me right now is the possibility that...
                            09-14-2024, 08:57 AM
                          • V3dran
                            Diffuser/LPG for UE50NU7022KXXH
                            by V3dran
                            I'm trying to repair a UE50NU7022KXXH with a cracked diffuser/lpg and now also with burned leds
                            There are 4/5 white spots on the bottom that are not visible since the left side is dark now so I want to change the diffuser/lpg
                            Looking the samsung spare parts, I see that there is a DIFFUSER PLATE and a LPG so I'm wondering what is really broken?
                            https://www.samsungparts.eu/samsung-...n61-15659a.htm DIFFUSER PLATE 1125x625x2,5mm
                            https://www.samsungparts.eu/samsung-...n61-15661a.htm LPG 1101x619x2,7mm...
                            06-26-2025, 01:54 AM
                          • mecha1166
                            Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
                            by mecha1166
                            Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
                            06-13-2024, 02:28 PM
