LG49UH603v No image backlight on
This topic has been answered.
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Originally posted by Diah
    at the end this IC my first time i saw it exploded , and its cant replaced with RAW one.
    it exploded because I used bad means to verify if it was too hot (Candel Debris)
    when i am going to replace it it has to be programmed ? in that case what do you need if you want to explain thanks it is on the way
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      Originally posted by lotas
      Hi lotas I have ordered that IC ps65175 but it will take very long to get it home. you can't find an equivalent IC that might be easier to get hold of and, above all, faster
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Hello again Lotas, Diah, EazyBone and everyone else who helped. Now this IC ps65175 is soon here and it must be programmed I think as Diah has said "it cant be replaced with RAW one" if so which program and programmer to use ? I have some that I have never used if you can explain I am very grateful​
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          no one to help solve tis issue?
          • Diah
            • Feb 2013
            • 6437
            we helping the possible things..LOL
            you ordered one from china i think... if you are lucky it will come fit as same parameters of yours.... Chinese have their black sources of chips ic to sell...LOL
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              #26
              Thank you Diah i know you are . but if its row ic how to do ?
              • Diah
                • Feb 2013
                • 6437
                raw one...i don't think so.. as Chinese sell what in black way... but if its indeed raw.. the TV will remain start... in_stop command to send for hard reset could write the temp in TV to the chip ... thought this theory only not tested just because this chip never saw in such condition
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  #28
                  Now the ic ps65175 is in my hands and I don't dare to do anything until I know for sure if it's programmed or not, and how do you know? Of course, the easiest way is to try it on the circuit and see if it doesn't explode again but I prefer another way to avoid waiting 3 more weeks
                  • Diah
                    • Feb 2013
                    • 6437
                    put it in circuit... it will not explode... , the one explode because you had before wrong / shorted LVDS
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      #30
                      thanks so much Diah ok i shall do but i am not very confident
                      • Diah
                        • Feb 2013
                        • 6437
                        to tell the truth --- i am too not very confident, just because the explode happen by yours hand wrong... so how will you solder this one in place correctly..with out damaging the boards.... LOL however hope and wish you have enough soldering skill
                        • lotas
                          • Jan 2016
                          • 4753
                          • Russia
                          #32
                          First, remove this chip and check the resistance where it was low (short) before, first with the panel disconnected, then connect the panel and check again where the short is, if the short appears again when connecting, then the problem is in the panel or in the buffer strips.
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            #33
                            Diah I'm practicing on the old circuit to be prepared when I put it in place but no don't be worried I'll manage to put it in place without hurting the rest you're funny you
                            • bohaboha
                              • Nov 2012
                              • 1017
                              • sweden
                              #34
                              Thank you so much lotas for your advice which I shall absolutely follow
                              Hope for even more support from all of you​
                              • bohaboha
                                • Nov 2012
                                • 1017
                                • sweden
                                #35
                                Hello all a little update now the IC chip ps65175 is removed and it went as you can see quite well because I have practiced with old board that I have under hand . now comes the difficult part or maybe the easiest because as you see in the pictures the old IC looks like it has had tin balls in the middle how do you think should I go about this IC chip
                                Any tips are more than welcome.
                                It looks like Short is gone now​
                                • lotas
                                  • Jan 2016
                                  • 4753
                                  • Russia
                                  #36
                                  The short circuits have disappeared, now connect the panel with the lvds cable and check again for short or low resistance (without this chip).
                                  • bohaboha
                                    • Nov 2012
                                    • 1017
                                    • sweden
                                    #37
                                    Ok thank you lotas will do and report .
                                    • bohaboha
                                      • Nov 2012
                                      • 1017
                                      • sweden
                                      #38
                                      it looks like it's ok no short but I'm a little doubtful about a capcitor don't know if it's ok the one closest removed chipset. can i measure it on the circuit?
                                      • bohaboha
                                        • Nov 2012
                                        • 1017
                                        • sweden
                                        #39
                                        Hi now I'm two steps away from repairing this TV, the first thing is to solder in place this ICIC7703 (TPS65175B) and need some advice before I start with it. As you can see in the pictures it has tin in the middle, lit needs a reballing ? I'm wondering how I should go about filling up those holes with tin? Or just put bak with just tin on the sticks all around? Any advice is welcome.
                                        the other is the loose Ribbon that needs to be back in place but we may have to take this after the ic chip is fixed​
                                        • bohaboha
                                          • Nov 2012
                                          • 1017
                                          • sweden
                                          #40
                                          This IC chip have to be reworked and i think it is best to use soldering's paste to rework it on board rather then using Mounting Solder Ball cause it is quite small area but no i think it is doable . any method will be ok. the problem here is the size of the solder ball or the paste that have to be used ? for this i need your help to guide me . very funny found myself already owner of this new station IRDA SMD & BGA REWORK STATION T-862++ that was in my storage room
                                          • Salem Aboshala
                                            820-00138-A got image but no backlight
                                            by Salem Aboshala
                                            Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                            I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                            History: my laptop backlight stopped working without any reason.
                                            Symptoms:
                                            I have image on screen using my flashlight.
                                            I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                            Keyboard backlight still working and can be adjusted normally.
                                            Since two days I tried to follow all similar...
                                            06-11-2024, 03:02 PM
                                          • zaurus81
                                            Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                                            by zaurus81
                                            This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                                            The board is equipped...
                                            01-16-2025, 03:54 AM
                                          • Constantinos
                                            Macbook Pro A2442 820-02098 No image but has backlight
                                            by Constantinos
                                            Hi all
                                            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                            Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                            08-24-2024, 09:48 AM
                                          • ajgae
                                            HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                            by ajgae
                                            Hi everyone!
                                            First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                            03-06-2025, 09:53 AM
                                          • learnmore
                                            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                            by learnmore
                                            Hello Community!
                                            CASE DETAILS
                                            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                            Tried inserting firmware on USB and left it in for a few hours, but no change
                                            03-03-2024, 09:49 AM
