LG49UH603v No image backlight on
This topic has been answered.
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    On this set new LED strip. Backlight on but no image
    have discovered very hot ic in red market in the picture plus some capacitor that are shorted on mainboard ,3v,5v,and 12v is in present want help deciding which is the bad boy
  • Answer selected by bohaboha at 03-27-2024, 08:53 AM.
    bohaboha
    • Nov 2012
    • 1017
    • sweden
    Originally posted by EazyBone
    Is this bad image or I this ribbon extremely dirty. Almost looks burnt
    Bravo EasyBone and Diah very good eyes you guys have. that Ribbon is restored because I accidentally bumped it off
    • Diah
      • Feb 2013
      • 6438
      yours photo LVDS NO 2 damaged .. or didn't fit in the socket correct.. do it again correctly
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        have checked them are well put in place
        • Diah
          • Feb 2013
          • 6438
          upload new photo of the LVDS NO 2. let see
          • bohaboha
            • Nov 2012
            • 1017
            • sweden
            On main board ic7703 and capactor next to it are really hot plus the 4 smd capacitor under coil 220n2 is short
            You were right about the LVDS one just in the picture​
            • Diah
              • Feb 2013
              • 6438
              sorry man.. yours eyes very bad or you are under stress alcohol this why do don't notice the fault its very clear at Socket NO 2 LVDS.
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                Click image for larger version  Name:	Untitled.png Views:	0 Size:	574.7 KB ID:	3242838
                yes it was not anymore se the last image not for the main board the pic was from thee first post but lvds you ask about
                • EazyBone
                  • Jun 2023
                  • 1353
                  • United states
                  • bohaboha
                    • Nov 2012
                    • 1017
                    • sweden
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      a little update now I have re-removed THE ribbon which was badly soldered . but I see that IC7703 is burnt see the pictures. what to do now. tried to find on the internet but can't find anything with the designations that are on IC7703 is there anyone who can help
                      • lotas
                        • Jan 2016
                        • 4753
                        • Russia
                        TPS65175B
                        https://aliexpress.com/item/1005002713379080.html
                        • bohaboha
                          • Nov 2012
                          • 1017
                          • sweden
                          Originally posted by lotas
                          thanks so much lotas.have there must be some other components around that are ruined
                          • EazyBone
                            • Jun 2023
                            • 1353
                            • United states
                            Buy new.main board. That should do it.
                            And dayummm that's a nice hole in the chip
                            • bohaboha
                              • Nov 2012
                              • 1017
                              • sweden
                              There is no way to fix the main board? The hole I think it's my fault I used part of a candel to see how hot it is and I cleaned it badly afterwards
                              • Donny2derby
                                • Apr 2023
                                • 228
                                • Uk
                                Lotas can you explain a few things on here for me?? I don’t expect you to know or tell me everything but just to help me with my own knowledge.
                                For example. What is pin 12 Swb? What is SWB? And what purpose are the two resistors in parallel with 2 caps in series doing? Why is OPT on there? Is this an optocoupler?
                                • Diah
                                  • Feb 2013
                                  • 6438
                                  this IC are programmable one. SWB software Bias, OPT are Optional in case in circuit non linear Diode in place. not as Zener diode... most all OPT on diagram you couldn't find them on the reality circuit as said Optional
                                  • Donny2derby
                                    • Apr 2023
                                    • 228
                                    • Uk
                                    Ahh brilliant Diah thanks. I did wonder what OPT could be and did consider I was making a mistake with optocoupler as this was not usual symbol for one.
                                    • lotas
                                      • Jan 2016
                                      • 4753
                                      • Russia
                                      12 pins SWB - 1.8V output voltage for panel buffer boards. Resistors and capacitors in this circuit serve as a filter for this power supply.
                                      • Diah
                                        • Feb 2013
                                        • 6438
                                        at the end this IC my first time i saw it exploded , and its cant replaced with RAW one.
                                        • Donny2derby
                                          • Apr 2023
                                          • 228
                                          • Uk
                                          Thanks very much Lotas. I’m beginning to understand a lot more about IC’s and things like Vcc thanks to you and Diah.
                                          Hopefully the next few projects I have lined up will give me chance to learn more and test more about this sort of thing without having to ask the very basics.
                                          • Salem Aboshala
                                            820-00138-A got image but no backlight
                                            by Salem Aboshala
                                            Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                            I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                            History: my laptop backlight stopped working without any reason.
                                            Symptoms:
                                            I have image on screen using my flashlight.
                                            I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                            Keyboard backlight still working and can be adjusted normally.
                                            Since two days I tried to follow all similar...
                                            06-11-2024, 03:02 PM
                                          • zaurus81
                                            Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                                            by zaurus81
                                            This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                                            The board is equipped...
                                            01-16-2025, 03:54 AM
                                          • Constantinos
                                            Macbook Pro A2442 820-02098 No image but has backlight
                                            by Constantinos
                                            Hi all
                                            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                            Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                            08-24-2024, 09:48 AM
                                          • ajgae
                                            HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                            by ajgae
                                            Hi everyone!
                                            First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                            03-06-2025, 09:53 AM
                                          • learnmore
                                            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                            by learnmore
                                            Hello Community!
                                            CASE DETAILS
                                            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                            Tried inserting firmware on USB and left it in for a few hours, but no change
                                            03-03-2024, 09:49 AM
