LG49UH603v No image backlight on
This topic has been answered.
  • bohaboha
    • Nov 2012
    • 1048
    • sweden
    #41
    Hi all no one to give some advices?
    • bohaboha
      • Nov 2012
      • 1048
      • sweden
      #42
      I will soon receive the Universal Stencil and Solder Paste Plus Soldering Balls to be able to complete the job Your suggestions are greatly appreciated
      • Salem Aboshala
        820-00138-A got image but no backlight
        by Salem Aboshala
        Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
        I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
        History: my laptop backlight stopped working without any reason.
        Symptoms:
        I have image on screen using my flashlight.
        I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
        Keyboard backlight still working and can be adjusted normally.
        Since two days I tried to follow all similar...
        06-11-2024, 03:02 PM
      • zaurus81
        Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
        by zaurus81
        This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
        The board is equipped...
        01-16-2025, 03:54 AM
      • Constantinos
        Macbook Pro A2442 820-02098 No image but has backlight
        by Constantinos
        Hi all
        I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
        He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
        Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
        Obviously, he decided against this and gave it to me so that I could have a crack at it.
        From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
        08-24-2024, 09:48 AM
      • ajgae
        HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
        by ajgae
        Hi everyone!
        First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
        03-06-2025, 09:53 AM
      • learnmore
        Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
        by learnmore
        Hello Community!
        CASE DETAILS
        Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
        13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
        Tried inserting firmware on USB and left it in for a few hours, but no change
        03-03-2024, 09:49 AM
