Sony LED 65X9005A shuts down after few seconds - looking for help
  • Diah
    • Feb 2013
    • 6500
    you wrote before... that you got green lines on the screen which they didn't bothered you.. now we are here at point to figure out what happen and where are the fault .. which it may be it fooled us ..
    my theory you got burning at first diffuser , and as we saw now broken parts are yellow... LED with age we can see it turned to being blue color.. so yellow + blue will mixed to being green.
    this is my theory.. but still i want to see the last plate which it was on chassis when you take diffuser all out.
    • tec3000
      • Mar 2024
      • 119
      this is my theory.. but still i want to see the last plate which it was on chassis w.hen you take diffuser all out.
      That is interesting!! I wonder if we can get rid of those lines too then...?
      About the diffuser. Is that the part that broke? I took some pics of it.
      Do you want me to unscrew the bigger plate on the other side?? Maybe you could you mark the area I should photograph?
      Much appreciated!
      • vinceroger69
        • Mar 2012
        • 6714
        #143
        The broken part is the led strips
        • tec3000
          • Mar 2024
          • 119
          hi vinceroger69 thank you. What did I order then if that's the strip? https://aliexpress.com/item/1005002859411201.html Click image for larger version
Name:	4pcs-set-LED-Strip-For-TV-XBR-65X900A-XBR-65X850A-KD-65X9005A-KD-65X9000A-KD-65X9000B.jpg_.jpg
          • Diah
            • Feb 2013
            • 6500
            the broken piece are just filter mounted over the strips.... stop doing any things till yours strip arrived
            • vinceroger69
              • Mar 2012
              • 6714
              #146
              Thanks for the clarification diah i have never seen that type of filter that goes over the led strips.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4518
                • Italy - Milan
                #147
                have you tested each led ? those can be ok.. (!)
                • tec3000
                  • Mar 2024
                  • 119
                  I can't. The filter is in the way. I tried to carefully remove it. Result is above. It breaks very easily.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4518
                    • Italy - Milan
                    #149
                    Sorry, i don't understand, each led can be tested with a 3v battery and a series resistor, so you broken a diffuser? And now? It's important to know if leds are ok, if you can or not continue the repair..
                    • tec3000
                      • Mar 2024
                      • 119
                      I also don't know what to do now. And where to get new filters/diffusers. I still don't know which is which.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4518
                        • Italy - Milan
                        #151
                        Ok, this is probably the end, but i want to repeat the move to dismantling the screen without checking well the led control board is definitely a rookie move.. as you can see led strips are not normal led strips (in series), leds are driven individually, so some leds not lit could be because of bad driver board.. this is not a professional way, this is a very well build tv set, sad seeing it go to landfill
                        • Diah
                          • Feb 2013
                          • 6500
                          Davi.p : when you will stop upset sets owner with yours rubbish comment... did you have eyes problem or its indeed one of yours hobbies to upset others ... can you explain yours professional what will yours genie 3V batteries will do with double LED unit build in double opposite zener protection Diode !!!? please please explain to other before you are talking on professional....
                          ignore such things which bothering you...
                          1- to remove the strips you need to push the strips at socket forward so the clips which hold it will be in the wide area so you can pull them.... install should be opposite things see the photo
                          2. to avoid the other side filter from any damage.. because it may burned and stitched to LEDs surface... spray the whole with alcohol over night so it will move easy.... the one which break... try start to clean it how much you can
                          Click image for larger version  Name:	1.jpg Views:	0 Size:	24.7 KB ID:	3250171
                          • Diah
                            • Feb 2013
                            • 6500
                            about the broken one... you can put them together with ( Sekund Kleber ) or ( UV Kleber )
                            i will recommend UV one as its 100% transparent and you can do it first in room then take it out under sunshine... just be sure it remain straight.
                            • tec3000
                              • Mar 2024
                              • 119
                              Thank you for the detailed description! I have now sprayed some alcohol. Tomorrow I will try to remove the strips.
                              I was also able to remove the other filters now without any problem! Nothing else broke. I was worried about the broken parts, but I will buy a UV-Kleber and put them together.
                              So if I understand you correctly it doesn't need to be 100%. Just have the filters at place. Right?
                              BTW: Strips are on the way now. 4 days in transit. I think it will be here sooner than I thought.
                              Thank you for assisting me!
                              • Diah
                                • Feb 2013
                                • 6500
                                NO. we need to do our best when you bring the broken one together at or nearly to 100% to avoid any light reflection or shadow,, because its located at he light source,
                                so to avoid the filters which mounted over ( under the LCD ) in crease any issue at light reflection.
                                • tec3000
                                  • Mar 2024
                                  • 119
                                  OK understood. I will pay close attention when gluing the pieces together. Thank you!
                                  Can you have a look at the pic I uploaded? This is from the other side. I haven't touched that side yet. As you can see there is a gap where the two filters meet and blue light shines though. It was already like that. Is that going to be a problem? It's exactly in the middle of the top of the TV
                                  • Diah
                                    • Feb 2013
                                    • 6500
                                    right now what we did saw..and know ,,
                                    1- the strips LEDs unit went blue color cause of burned the surface of them..( we don't need to explain the chemistry of LED )
                                    2- the first filter also effected with some burn from the LEDs surface. ( this need to try clean them how much u can with out damage the coating )
                                    3- from the photo you upload for LED driver boards there are much brown area happened via heat ( over load ),, until now we cant say this boards got issue or not.... as the reason was the strips
                                    also you are now removing the reason with new strips then you can go back to others points if there are an issue.
                                    so step by step repair called
                                    • tec3000
                                      • Mar 2024
                                      • 119
                                      Diah Alright, thank you for the explanation. Once the strips arrive I will let you know. Appreciated!
                                      • tec3000
                                        • Mar 2024
                                        • 119
                                        Hi, I finally got the LEDs. I attached them. So far the TV doesn't turn off! (I tested for 15 minutes. Never lasted this long with the old ones)
                                        So far so good BUT:
                                        Please take a look at the new pic. One strip has far more light output than the other 3 strips as you can see from the attached picture. Any ideas why? I wanted to do the reassembly now but not sure....
                                        edit: It's actually not the entire strip. Only the outer half. Towards the edge.
                                        Click image for larger version  Name:	1713775724688.jpg Views:	0 Size:	2.00 MB ID:	3257457
                                        Last edited by tec3000; 04-22-2024, 03:48 AM. Reason: edit: It's actually not the entire strip. Only the outer half. Towards the edge.
                                        • Diah
                                          • Feb 2013
                                          • 6500
                                          dont bother of more light or less... you don't have the screen in place and no signal the dimming process will be different.., put every things bask as it should.
                                          • riko 656
                                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                            by riko 656
                                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                            Laptop Model:
                                            • Model: Lenovo Legion Slim 5 16APH8
                                            • GPU: NVIDIA GeForce RTX 4070
                                            • Main BIOS chip size: 32MB
                                            • VBIOS chip size: 16MB
                                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                            What I Have Tried So Far:
                                            1. I
                                            11-04-2025, 05:14 AM
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • riki_22
                                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                            by riki_22
                                            I’m working on an ASUS B5402CEA notebook.
                                            B5402CEA_MB_R2.2
                                            HA4YT LA-L861P
                                            REV:1B
                                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                            I suspect the BIOS might be corrupted.
                                            Could someone please check and clean (repair) the attached BIOS dump?
                                            I’ve also attached a few photos of the motherboard for reference.
                                            Thanks in advance for your help!
                                            11-03-2025, 04:38 AM
                                          • APOPAP
                                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                            by APOPAP
                                            Hello everybody,
                                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                            The same question is also posted on another site, here it is:
                                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                            08-25-2025, 10:12 AM
