Phillips 42PF7220 Plasma TV
  • spike3333
    • Jan 2014
    • 43
    I'm new to the Forum so excuse me if I don't appear to know what I'm doing (I don't).
    I have an old Phillips 42PF7220 Plasma TV that has been pretty reliable for years. I have done some of my own repairs. I replaced a Y-Buffer board in January of 2012.
    Today it started acting up again. My wife turned it on and the picture appears very faint, as if it's being viewed through a black fog and the image has a red tint to it. You can see the picture in the image I posted above.
    Has anyone seen anything similar on their plasma? Do any of the experts on the Forum have any suggestions as to repair. I think it's a 2004 so it may be ready for pasture. I thought I would give it a shot instead of adding to the landfill.
    Thanks,
    Dwight
    Re: Phillips 42PF7220 Plasma TV
    Clear cut Z-sustain / X-main failure right there.
    • spike3333
      • Jan 2014
      • 43
      Wow talk about prompt replies. I had just gone out to the garage to set the TV up on the bench and came back to see your reply, thank you.
      In the manual I have it shows a PCB to the right of the power supply called the PDP X-Main. Is that what I want to replace? Is the Z-Sustain a separate PCB? If so could you point me in the region I should be looking for it.
      Thanks again Tom,
      Dwight
        The Z-sustain and X-main are different names for the same part, in your case, it is X-main because the panel (display) components are made by Samsung.
        • spike3333
          • Jan 2014
          • 43
          Tom,
          I have the backcover off and it looks a little different than the manual. Is this the one:
          Once I have the board out is there a chance i just need to replace some blown caps or it do I need to replace the whole board?
          Thanks,
          Dwight
            Yes, that is the X-main.
            • spike3333
              • Jan 2014
              • 43
              They go for $20 to $40 on eBay, I guess I'll go new.
              http://www.ebay.com/itm/Samsung-HP-R...item5890a1cfaa
              The ads are for "Samsung HP-R4272 X SUS Board LJ41-02758A or LJ92-01199A". Are these fairly universal or do I need to get something more specific to my model.
                Yes, they are universal parts. Just match the LJ41 and LJ92 numbers printed on the old X-main board to that auction, usually it is OK if the last letter (A,B,C typically) does not match but the rest must match.
                • spike3333
                  • Jan 2014
                  • 43
                  Darn. One screw in the middle edge of the heat sink I can't readily get to. I guess it was all going too smoothly.
                    You don't need to undo the heatsink. Be careful with the orange ribbons going into the glass panel; they cannot be replaced or repaired if torn.
                    • spike3333
                      • Jan 2014
                      • 43
                      There is a perimeter PCB screw that is accessible through a hole in the edge of the heat sink. It's under one of the vertical frame members. I have all the flex undone. I'm familiar with the ZIFF style connectors from my days with Motorola.
                      The TV has been unplugged and sitting in my garage for over 24 hours. Should all the caps be dissipated?
                      I ordered the PCB and paid for overnight shipping. Hoping I get this up and running before the Superbowl on Sunday.
                        On the X- and Y-main boards, discharge occurs within about 10 minutes typically. The "test-before-touching" rule is a good idea, though.
                        • spike3333
                          • Jan 2014
                          • 43
                          Thanks again for all your help. I'll let you know how it all works out.
                          • spike3333
                            • Jan 2014
                            • 43
                            Hi Tom,
                            I got the replacement X-Main PCB and installed it. The Tv looks the same. Any thoughts?
                            Thanks,
                            Dwight
                              We had one here which was not resolved by X-main. It turned out to be a bad component on the control board feeding into X-main. It required in depth analysis and about 100 posts but we did sort it out. I'll see if I can dig out the thread. IIRC, an oscilloscope was necessary.
                              • spike3333
                                • Jan 2014
                                • 43
                                Tom,
                                I'm second guessing whether I fully seated the small latch ZIF connector leading into the board. I'll open it back up and double check. Could this explain it?
                                I don't have an oscilloscope and it sounds like it will be beyond my capabilities but I would like to hear what was discussed in the earlier thread.
                                Dwight
                                • spike3333
                                  • Jan 2014
                                  • 43
                                  Hi Tom,
                                  Any luck locating the other thread. I was going to open the TV back up this weekend and work on it.
                                  Thanks,
                                  Dwight
                                    https://www.badcaps.net/forum/showthread.php?t=24872
                                    Sorry did not see your previous posting.
                                    • spike3333
                                      • Jan 2014
                                      • 43
                                      OK great. I read through the thread. I don't have a oscilloscope. If I find that I have the new X-Main well connected would it be worthwhile to test the resistances across the resistor banks you indicated in the thread? I have a multimeter. I'm a mechanical engineer but am pretty clueless with electronics.
                                      • spike3333
                                        • Jan 2014
                                        • 43
                                        Tom,
                                        I have the TV apart again and it appears all the connections to the X-Main are solid. Are there any tests I can do without the oscilloscope I can do? I have a multimeter. I included a picture of the logic board in my TV that is connected to X-Main by the narrow flex.
                                        Dwight
                                        • Uranium-235
                                          Phillips 50PF7321D/37 Plasma slow reboot
                                          by Uranium-235
                                          Customer said if he keeps it on for a long time, turns it off, and later back on, it takes 10 minutes to get to proper brightness. Is this just a cap issue? I didn't have time to take it apart I was just there to drop a repaired laptop off
                                          12-27-2021, 09:14 PM
                                        • ArMaaN376
                                          Samsung PS51E550 Plasma TV
                                          by ArMaaN376
                                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                          Opened TV cover & observed foll
                                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                          How to confirm Y -Buffer board...
                                          06-19-2024, 04:05 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • porfyriadhs
                                          Samsung Plasma PS51D6900DS Bootloop
                                          by porfyriadhs
                                          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                                          Thanks a lot !!
                                          10-19-2023, 11:31 AM
                                        • SurrealMustard
                                          What parts can be salvaged from a plasma with a damaged display panel?
                                          by SurrealMustard
                                          I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                                          03-09-2025, 08:29 PM
