Philips 50pus6503/12
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    Hello to everyone. I have problem with the Philips 50pus6503\12. I have bacight but no picture . Tried removing ribbon cables, the left one then the right with no lunk. Then I tried to put some tape to cover the lines but nothing changed at all. Need help thanks
  • porfyriadhs
    • Oct 2023
    • 80
    • Greece
    • Diah
      • Feb 2013
      • 6440
      flash firmware again with format upgrade-_loader
      • yokoono
        • Apr 2010
        • 505
        Try this. Unzip, put on a stick (formatted FAT32), unplug the TV, plug the stick into the usb, plug the TV into the socket. Update starts. Wait for it to finish.​
        https://files.fm/u/8xku5qkpg6
        • porfyriadhs
          • Oct 2023
          • 80
          • Greece
          First i thought that was a shorted panel issue . I will try on Monday
          • porfyriadhs
            • Oct 2023
            • 80
            • Greece
            need to name of the folder ? . I was waiting 5 minutes nothing changes
            • yokoono
              • Apr 2010
              • 505
              1. There is no folder
              2. It is a single file
              3. Also try renaming upgrade loader.pkg​
              • porfyriadhs
                • Oct 2023
                • 80
                • Greece
                • yokoono
                  • Apr 2010
                  • 505
                  OK. Put the file on the stick and try again.
                  • porfyriadhs
                    • Oct 2023
                    • 80
                    • Greece
                    Nothing changes 😵😵😵
                    • Diah
                      • Feb 2013
                      • 6440
                      download this file--- unzi it and copy the file on usb stick.. formated in MBR mode fat32
                      • porfyriadhs
                        • Oct 2023
                        • 80
                        • Greece
                        ok i did everything right for the first 5 min it was with a black screen and eventually it starts but without image only backlight
                        • William1967
                          • Nov 2017
                          • 215
                          • Netherlands
                          Reloading the firmware (upgrade_loader) also makes little sense if there is no image. Then you would benefit more from resetting the Setoption, even though in this case it seems to me that the panel has a problem. Measure whether the t-con receives 12V and then you can measure some voltages on the t-con. An important one is the 15V to the panel.
                          • porfyriadhs
                            • Oct 2023
                            • 80
                            • Greece
                            I have 12 volylt. But all the other volts are low
                            • porfyriadhs
                              • Oct 2023
                              • 80
                              • Greece
                              • yokoono
                                • Apr 2010
                                • 505
                                Measure VGH (positive) and VGL (negative).​
                                • porfyriadhs
                                  • Oct 2023
                                  • 80
                                  • Greece
                                  no voltages ...around 0.7v
                                  • yokoono
                                    • Apr 2010
                                    • 505
                                    1. If VGH and/or VGL disappear when you connect the ribbons from the panel, you have problems with the panel.
                                    2. If VGH and/or VGL are not there even if you have disconnected the ribbons from the panel, then you have a defective T-con. The T-con can also burn due to a defective panel.
                                    3. There are T-cones that come into protection when the ribbons are disconnected.​
                                    • porfyriadhs
                                      • Oct 2023
                                      • 80
                                      • Greece
                                      i tried bot with the ribbons and without . It is the same
                                      • yokoono
                                        • Apr 2010
                                        • 505
                                        If the T-con is supplied with 12V and VGH/VGL are missing when the ribbons are disconnected, it may be a defective T-con or in protection. With the mention that the T-con can also burn due to a defective panel.​
                                        • silikon77
                                          Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
                                          by silikon77
                                          Hi!
                                          Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
                                          Found some advices watching youtube nad came up with this:
                                          It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
                                          I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
                                          See attached picture.
                                          I tried a few combinations to block individual clock...
                                          01-02-2025, 02:26 PM
                                        • RetroComputingGrotto
                                          IBM LTO 7 Tape Drive - Dust Sensors??
                                          by RetroComputingGrotto
                                          I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                                          I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                                          09-19-2024, 01:54 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • ezenia
                                          PS4 controller left stick potentiometer replacement issue
                                          by ezenia
                                          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                          09-30-2023, 02:19 PM
                                        • triplefour
                                          LG 75UN8570AUD panel issue fixed with tape.
                                          by triplefour
                                          I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                          add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                          07-17-2023, 10:22 PM
