Philips 50pus6503/12
  • William1967
    • Nov 2017
    • 215
    • Netherlands
    Check the smd capacitors on the t-con, maybe one is s/c.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4464
      • Italy - Milan
      You are not following the right steps... 1st, one must not rewrite the SW if not shure or at the last beach (as we say here) , the symptom sounds as bad screen assy, first thing to do is screen self test, withdraw 12v from psb and connect it to the tcon fuse, detach MB lvds cable, turn power on, if screen produces correct self test the fault is on MB.. second, it is highly likely that tcon has no load protection so detaching the panel or half inhibits outputs, therefore you start checking panel strip boards for SC condensers/diodes, OC resistors... if all ok then bad gate drivers (masking tape etc..)
      • silikon77
        Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
        by silikon77
        Hi!
        Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
        Found some advices watching youtube nad came up with this:
        It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
        I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
        See attached picture.
        I tried a few combinations to block individual clock...
        01-02-2025, 02:26 PM
      • RetroComputingGrotto
        IBM LTO 7 Tape Drive - Dust Sensors??
        by RetroComputingGrotto
        I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
        I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
        09-19-2024, 01:54 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
      • triplefour
        LG 75UN8570AUD panel issue fixed with tape.
        by triplefour
        I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
        add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
        07-17-2023, 10:22 PM
