Hi all, I have had this Philips TV for about 8 years and it finally has given me a problem. When you turn it on now there will be no picture for awhile. Eventually it will get a picture. It has sound the whole time and the light on the front stays green the whole time. Once it has a picture it stays on until it is shut off. Any help in fixing this would be much appreciated. It has been a good TV.
Philips 37PF7320A/37 no picture
Re: Philips 37PF7320A/37 no picture
So if you turn it off then turn it back on immediately does the picture come back quicker than it would if it was off for the night?
When there's no picture check in a dark room - does the screen glow at all?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
OK, does the picture fade in slowly... or is it suddenly available?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Can you provide a picture or video of this flickering?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
maybe tomorrow. the tv works too well now to get it to act up. the best way to describe it is the part of the picture that shows the input is scrambled about the screen in streaks when you switch inputs. so a black screen with a couple grey/white streaks.Comment
by RauniHello, this is my first post on this forum, and my first attempted to repair a TV.
My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
Read also that we should test what happens if we... -
by SchwoinHey everyone,
the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
you can see them on the top half of the photo.
At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
by madyoyoHI.
I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming.... -
My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
Is there someone having any symptom like this? How to fix it?
Thanks in advance!08-06-2024, 09:55 PM -
by groomitHi,
I'm having trouble with above mentioned TV. Bought it defect.
Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
I can see backlight, but screen stays black.
What I've tried:
- Disconnect right side cable from T-Con -> same (backlight but no pic)
- Disconnect left side... - Loading...
