Vizio vp422hdtv10a won't turn on
    Re: Vizio vp422hdtv10a won't turn on
    ^correction above, "separate transistors"
    Looks like Y-sus is bad then.
      So do I assume the buffers are ok? I hate to replace the Ysus just to have it blow again cause the buffers are bad.
        And they say to replace both Ysus and Xsus at the same time but I think the Xsus is ok.
          This set doesn't chain ER circuits, so you do not need to do that.
            Ok Tom thanks for all your help I sure appreciate it, I ordered a used Ysus from ebay and i'll let you know the outcome.
              Ok I got a used Ysus off ebay and the voltage on VSC is -188.7v , when I power it on I get nothing on the screen. When I check voltages on the pins that go into the buffer board the first 2 pins on the first connecter CN5003 I get -35.4v and the third pin is a continuous MV reading, all other pins read -160.4v and CN5002 and CN5001 are all -160.4v. Any suggestions what to look at next?
                I unplugged the buffer board and checked pin voltages, the first 2 go from a negative -35.4v to a positive 22.4v with the 3rd pin doing the same with a continuous moving MV reading ,all other pins read -115.5v
                  Anybody have any idea's if the buffer is bad or is there another problem or something else to check?
                    Have you checked the Y buffer to see if its grounding,from + to - at the plug from the Y main.
