Sony KD 49X8307C
  • lotas
    • Jan 2016
    • 4753
    • Russia
    #121
    Panel - (SYV4941) LC490EQL (SH) (A2)
    • Donny2derby
      • Apr 2023
      • 228
      • Uk
      #122
      This is board in my Tv mate.
      • Diah
        • Feb 2013
        • 6437
        PSU - TCON- Panel no match
        • Donny2derby
          • Apr 2023
          • 228
          • Uk
          #124
          What are these Lotas? Boards that are suitable for my Tv?
          • Donny2derby
            • Apr 2023
            • 228
            • Uk
            #125
            No that is the part number of MB Diah. Do you want me to give part numbers of PSU & TCON?
            • lotas
              • Jan 2016
              • 4753
              • Russia
              #126
              No, this is your panel number, and this is your motherboard, look for this number - MAIN: 1-894-595-12 (Y210B300C)
              https://www.electromix.co.uk/main-pc...7864-ww3b.html
              • Donny2derby
                • Apr 2023
                • 228
                • Uk
                #127
                Yea these are the boards I have searched for and all are out of stock. I have notifications set for when they come back available.
                • harp
                  • Jun 2022
                  • 622
                  • Planet Earth
                  #128
                  you need to remove the black heat sink and the metal weight put it on the top of the chip
                  I am interesting for origin of this method with weight on top... while watching a lots of video, never seen this technique for bga chip?
                  • Donny2derby
                    • Apr 2023
                    • 228
                    • Uk
                    #129
                    Diah I have found a repair service for the main board on eBay. He is charging £89 for this. Do you think this is worthwhile and are you confident that a repaired main board is going to give me a working telly? If I spend this money and Tv still doesn’t work I’ll be very very sad.
                    • lotas
                      • Jan 2016
                      • 4753
                      • Russia
                      #130
                      If the board is deformed from heating under a load, then it is unlikely that it can be restored, since the chip will not be able to lie flat on the seat (some bga balls will not come into contact with the board), this must first be discussed with the service...
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        #131
                        Ok lotas. So if I message the guy to say I will pay for the repair but if it comes back as not successful can I have a reimbursement??
                        • lotas
                          • Jan 2016
                          • 4753
                          • Russia
                          #132
                          Explain the entire history of this motherboard (the initial malfunction and what you did with it later), if they agree to repair, discuss everything in advance.
                          • Donny2derby
                            • Apr 2023
                            • 228
                            • Uk
                            #133
                            Yep. I’ve explained that the PSU had all expected voltages and that I’ve previously attempted a home repair which has resulted in me losing 12v REG & 12v T-con
                            Ive also told him it was you that told me to take a heat gun to it for 10 minutes! You’re name is now very low in TV repair circles 😛
                            • lotas
                              • Jan 2016
                              • 4753
                              • Russia
                              #134
                              Yes, I should have said that he also recommended baking it in the oven, but you didn’t do it!
                              • Donny2derby
                                • Apr 2023
                                • 228
                                • Uk
                                #135
                                Is that something you would recommend?
                                • Diah
                                  • Feb 2013
                                  • 6437
                                  users with limited mind would find its strange.. but to normal user at home with out professional tools, we can say "Necessity is the mother of invention"
                                  did you programmed in your life head robot for mounting CPU / SOC ? what did the suck of the head do while Infrared starting packing.??? nut all of you includse Lotas just believe on on what you have tools under hand.. no one of you put his self in shoes the normal user.., what the different of manufacture oven and the process at home... ???? some things sound funny but its effective, so stop laughing on yours self and appreciated any offer to help with less cost.
                                  at the end all of you never worked on MB,,
                                  don't send yours boards to any ... find replacement.... no one can repair it with out its panel and T-CON.. this is just fraud, other wise i asked you to send it to me and i reball it for free... still i cant test it unless on the complete set.. so its just waste of time and offered.
                                  • Donny2derby
                                    • Apr 2023
                                    • 228
                                    • Uk
                                    #137
                                    The repair service on eBay does say that it is necessary to send MB and T-con! So it sounds like he may be legitimate? Maybe he has spare Sony Tv to help enable repair? You still think is no point?
                                    The problem is Diah that it is not possible to find replacement board on google search now! Every company has advertised board as not in stock. So I don’t think I will be able to find one.
                                    I think tomorrow I will put TV back together and store in the loft. If in the next few months a new MB becomes available then I can start again. But for now this TV is not repairable.
                                    • lotas
                                      • Jan 2016
                                      • 4753
                                      • Russia
                                      #138
                                      nut all of you includse Lotas just believe on on what you have tools under hand.. no one of you put his self in shoes the normal user.., what the different of manufacture oven and the process at home... ???? .
                                      Diah, do you have any idea what will happen to the motherboard if you turn on the oven to maximum (up and down) and keep the motherboard in it for 20 minutes?
                                      • Diah
                                        • Feb 2013
                                        • 6437
                                        its is not about if he legitimate or not... he may being here too as user... but this is belong not only to MB and T-con .. what about the panel... did he will said its repaired because the screen show lines at his side ??? or send you photo of somethings ells..
                                        my last advice, do the packing i explained how... if didn't succeed. put it on side till you find replacement or set with broken screen.
                                        • harp
                                          • Jun 2022
                                          • 622
                                          • Planet Earth
                                          #140
                                          No, I am not working with that... and dont know what is doing robot arm (and why) while going heating is applied.
                                          I appreciate any help naturaly, but just not find any reference about method you mentioned to understand principle of that technique.
                                          To me it is not adequate to just hear new information, I always tend to understand indepth about it, maybe I dont ever needed or use it but like to can say to know it for sure, not only to have hear from where, NHF. Anyway I am not sure what is concerned like problem and how to achieve to fix it with this method?
                                          I am interesting to learn any new technique to me, so that is why I am stuck here... I found your information unknown to me, and cant logicaly explain myself whats can be results else of very squised balls who may touch itself?​
                                          • x_orange90_x
                                            Sony KD-75X750H no backlights
                                            by x_orange90_x
                                            I just removed the back cover to test the backlights because when I first plug it in it will flash once and then start dark but I can see the image. I got 131v on string 1 and 167v on string 2. Usually when I get a bad set the meter reads 300v and they won't light up. When testing, each set lights up inside the tv. When I plug in the power and check the leads with my multimeter both strings are only about 3v.
                                            Does this difference in voltage between the strings indicate that the lesser has bad LEDs? Or is it normal that they are not the same voltage? I've read some about this tv and...
                                            07-16-2025, 07:49 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
