I have one from a pn64e533. I replaced the 3BR2565JF and the two 18n50 (used 22n60 that I had on hand). I now have standby, vs, va, and 15 volt rails. When I reinstall it the relay just clicks. Swapped it out with a good power supply and the tv works. What do I have to do now to repair it?
BN44-00515a
Maybe, it's 64 inch.
Some information is lacking, what else other than the 3BR and the other two mosfets was checked.
Are all components on the backside near where the 3BR was soldered fine?
No ceramic cap exploded?
Was a power up test without the main board done with the other boards connected?Comment
It is a Pn64e533, a 64inch. If you connect ANYTHING to the power supply, the relay just clicks at 2 times a second. I don't understand how the voltages can be close to spot on when ps on to gnd and vs on to 5v are wired up. I only replaced thr 3BR2565JF and the two 18n50 mosfets. I removed the two I substituted for them(22n60) with originals. Still had same symptoms.Comment
if you mean PS_On read GND after plugging load on PSU... then you have to check the optocoupler of PS_ON circuitLast edited by Diah; 02-25-2024, 03:30 AM.Comment
by RensieeHello,
I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
I have measured the voltage in the VSUS line, which...06-18-2024, 12:58 PM -
by momakaI got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
Problem:
Backlight cycles On and Off.
Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark.... -
by samtron786Hello
The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
2-3 seconds later the relay will click again and only the red LED will stay on.
I would be very grateful for any advice or a little help.
circuit diagram?
Thanks very much -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by jm1234Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but... - Loading...
