Samsung UE32D6515WS — boot loop + what does this pixel pattern suggest?
  • ohren
    • Mar 2015
    • 119
    • Sweden
    I'm trying to determine the nature of these faults and whether they're coincidental or in fact connected.
    Symptom 1: boot looping, showing logo and then going blank, backlight turning on for 2 s or 14 s intermittently, and arriving at logo again after approx 1 minute. Never appears to boot fully.
    Symptom 2: vertical lines across whole screen while logo showing. Every 4th pixel column.
    Backlight seems to work fine and is lit while logic board is disconnected. 12v, 5V seem stable and only dip when the system resets.
    System still seems to reboot when T-con board is disconnected. Same when LCD disconnected.
    Everything on the boards looks more or less pristine. I can't pinpoint it more than it's either the logic or T-con board.
    I do repairs for fun, i.e. I'm always interested in early opinions on whether the fault is likely to be extremely tedious or needlessly expensive to troubleshoot.
  • ohren
    • Mar 2015
    • 119
    • Sweden
    Is there any additional info I can provide to help someone lend their intuition about the pattern?
    Here are some clues:
    • The visual artifacts occur on every fourth pixel column
    • They seem to always occur on the same columns between reboots
    • They occur over the boot image
    • The boot image seem to affect the appearance of the artifacts (what looks like the image's bounds become discernible — imperfect black background color in interplay with the fault?), i.e. what the picture is supposed to look like seems to have an effect on the artifacts
    • The artifacts differ between reboots
    • The artifacts are static each boot and do not flicker in the few seconds they're visible
    My conclusions:
    • The artifacts are stored in some frame buffer since they are stable and don't flicker
    • They occur before they're sent to the t-con board
    • They're somehow connected with the CPU or with the component responsible for feeding the t-con board
    Since I'm not that familiar with TV architectures my assumptions are:
    • The display of initial boot images are not handled by the t-con board, but by the logic board
    • The logic board feeds the t-con board a fixed number of frames per second (I.e. everything beyond the logic board is basically fixed frame rate signals)
    Does anyone have a hunch? Are my assumptions wrong? Is it futile to reason about faults like these in this way? I'm happy just learning how to decide where to put my focus.
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • Takeatry
      Yet another Samsung QLED Boot Loop
      by Takeatry
      Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
      10-04-2024, 02:57 PM
    • blaster_
      Samsung UE49MU6105K - boot loop, horizontal lines
      by blaster_
      Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
      Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
      06-22-2022, 05:19 PM
    • torchzack
      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
      by torchzack
      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
      08-28-2023, 07:42 AM
    • No Lan
      [Macbook pro A1708] [Boot loop] [Trackpad ?]
      by No Lan
      Hey everyone,
      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
      05-24-2025, 03:09 PM
