Well lets make sure on that resistor, is it visible on here, if not what are the colors on it?
Samsung UN50KU6300F constant reboot, bad backlights?
Originally posted by nomoresonys View PostWell lets make sure on that resistor, is it visible on here, if not what are the colors on it?Last edited by x_orange90_x; 02-20-2024, 10:11 AM.
Originally posted by x_orange90_x View PostI tested the SK34 diode on the bottom and it appears to be bad. It checks .298 both directions with one meter and 4.8 both directions with my other meter.
I have a spare board with a similar size but it's an SK510C. Could I safely use this in place of the SK34?
Here's one resistor chart, pretty easy to use, check some other resistors to see if you get a correct reading, wondering if your meter battery is ok: https://kiloohm.info/smd4-resistor/1004
Shit, my bad, that one is for surface mount, let me grab the thru hole one, here: https://www.digikey.com/en/resources...tor-color-codeLast edited by nomoresonys; 02-20-2024, 06:45 PM.
Is it black-blue-silver-gold, I get .06 ohms, if those colors are correct, then even 1.2 ohms is way out of specs, then as usual when a reading seems off in circuit lift a leg and check ooc.Last edited by nomoresonys; 02-20-2024, 06:57 PM.
Originally posted by nomoresonys View PostIs it black-blue-silver-gold, I get .06 ohms, if those colors are correct, then even 1.2 ohms is way out of specs, then as usual when a reading seems off in circuit lift a leg and check ooc.
I checked other resistors on the board and got similar oddball readings. I think the resistor ok. That one diode on the bottom has been mentioned on these forums several times as causing these symptoms. It's surface mount, so if I take it off to test I'd be replacing it as well.
Originally posted by nomoresonys View PostAbsolutely, I do believe that diode is bad.
Ir is blank on the datasheet for the SK310C.
I replaced the diode on the bottom and I STILL have the same symptoms!
Edit: I removed a leg of that resistor and checked it. It reads 0.00 ohm 😑Last edited by x_orange90_x; 02-21-2024, 10:32 PM.
black, blue, silver, gold is correct. When I looked it up I got 600 M ohms. Maybe I did something wrong
Originally posted by diif View Post
Double check the resistor value using one of the many available websites.
Also, my reading of 0.00 ohms means my resistor is bad, right?
Edit: it has to be silver because that's .06 Ohms. Grey would be 600 MegaOhms. I can't however find a .06 Ohms resistor online.Last edited by x_orange90_x; 02-22-2024, 05:35 AM.
It looks like it can't be either of those. 600 M ohms would be a huge resistor, and from what I'm finding .06 ohm doesn't even exist.
I can't find a schematic for this board either
Edit: wow this is frustrating. I can't find a schematic, therefore I can't see on paper what the value is supposed to be. Likewise, searching for the board number and "R9022" turns up absolutely nothing. And to top it off I'm finding this exact same model board with a completely different 5 band resistor instead of the 4 band I have.Last edited by x_orange90_x; 02-22-2024, 06:20 AM.
I gave up on diagnosing the original board and just ordered one from eBay. I put it in last night and the tv is working great.
My advice to anyone else with this model power supply is to just get a replacement. There's too many things that fail on it and getting it working may only buy a little bit of time before another component fails.
Originally posted by nomoresonys View PostGlad to hear it, Indeed when you figure all the time that can be spent trying to troubleshoot, if a board is available for a fair price, it sure can be the best way to go, it may also preserve a little sanity, lol.
