LG OLED65C14LB horizontal lines on screen
  • Chrissygizmo
    • Mar 2021
    • 108
    Hi all, just a quick question, I'm sure someone can help me out...
    I've been asked to have a look at a LG OLED65C14LB TV to repair horizontal lines across the screen, I will post a picture of the screen. If anyone c
  • Chrissygizmo
    • Mar 2021
    • 108
    • EazyBone
      • Jun 2023
      • 1309
      • United states
      Either tcon board or it's the panel. My 2 cents. Tcon generally pretty cheap. Panel makes it trashola. Maybe someone here can steer you into how to test the TCON and or panel.
      • Chrissygizmo
        • Mar 2021
        • 108
        Thank you very much for your help, I was wondering if it could be just the sellotape job over the clock lines
        • EazyBone
          • Jun 2023
          • 1309
          • United states
          From what another had said on here that can cause a fire on oleds. I don't have experience with that I just recall something about using tape on oleds is a bad idea.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4291
            • Italy - Milan
            I would try a repl. TCON, if you will do, you have to get one from cracked screen, peremptory!!
            • kdaniel
              Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
              by kdaniel
              As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
              There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
              After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
              Left...
              11-16-2022, 09:23 AM
            • ggil44
              Sony XBR-65X750D Horizontal lines bottom of screen
              by ggil44
              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
              05-30-2023, 07:51 PM
            • Stanley1843
              Screen Display Vertical Multicolor Lines
              by Stanley1843
              Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
              06-29-2024, 11:54 AM
            • theo321
              Horizontal black lines on screen - please for your help
              by theo321
              Hello Everyone
              I need your help to repair my poor Samsung TV which decided not to let me watch my favorites series in the afternoon. Suddenly black horizontal lines appeared on the screen making my life a hell
              Photo:
              https://ibb.co/Kyhm9M5
              Close up photo:
              https://ibb.co/zNtv4XP
              I have seen many youtube videos with guys who put a tape in ribbon cable and TV fixed in a magic way (I have tried without success).
              My TV model is: LE46C750R2W
              Photo:
              https://ibb.co/Q6RFN94
              I have tried to disconnect one...
              06-19-2023, 04:28 AM
            • Runlinc
              Samsung QE50Q60TAU - Horizontal screen lines
              by Runlinc
              Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
              I am left with a good image apart from the black horizontal lines that I cannot get rid of.
              I cannot find anything on the buffer boards that has shorted.
              Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
              Many thanks for your assistance
              05-14-2024, 07:40 AM
