Latest firmware for an LG PDP42X3 Plasma Control-Board for official SVC kit?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Ive had a look on LG site--but it looks to be a service-subscription only type scenario.
    I have the (infamous) 42PC1D, with the PDP42X3 xx series panel--showing the red-dot syndrome of mal-discharge, needing a Control-Board firmware update to cure....
    Ive got the Blue-Chips/L.G. official SVC kit with the Update board, cables and CD, but the CD is dated 2007, It covers a lot of different models and versions of the PDP's including the one I need, but I'm guessing there must be a more recent version by now, and its not something I relish doing--twice......
    I have other faults on the set, so I'm going to look at that fault first, mentioned in a different thread, and then fire up my old laptop--as the driver software for the update-board is based on 32 bit, --wont work on win7!
    Any ideas?
    TELEFIX
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Latest firmware for an LG PDP42X3 Plasma Control-Board for official SVC kit?
    Well--I lucked out!
    My old PC has win7 too! forgot that! So, how do I run an early USB update board driver on win7??
    TELEFIX
    • anotherdude
      • Feb 2013
      • 488
      • uk
      windows 7 does support 32 bit providing your running he x86 version and not the x64 but both should work anyway
      if you have issues try running it in compatibility mode
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Cheers--I'll give that a bash later....
        TELEFIX
        • AlexWhat
          SONY KDL-65w850c need latest firmware 6.827
          by AlexWhat
          In 2022 SONY did "Termination of TV Software Update" for this model.
          I did find older firmware but it can't be installed over newer one (rolled back)
          Yes, got boot loop during android load so if that will not work then EMMC has to be replaced, I think.
          12-15-2024, 11:32 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
        • Fireballcz
          Synology DS109 latest firmware (PAT file)
          by Fireballcz
          Hello friends,
          I need the latest firmware for Synology DS109.
          The filename is DSM_DS109_3259.pat (about 170MB).
          Umpossible to download from Synology, because their support for old devices is discontinued as of 2023-05-31.
          Please does anybody have a backup?
          Many thanks in advance.
          07-03-2023, 02:39 PM
