Samsung qe50q60Tau t con problem
This topic has been answered.
  • Dave03
    • 4
    • Magyarország
    Hi everyone so sorry my bad english Im hungarian
    so I have a few samsung qe50q60tau and I trying to repair t con problem, I have a 100% working main board 100% working psu for the tv for another tv I replace them boards for the wrong tv and the problem was same so the problem not the main board and not the psu, the back light is working
    I turn on the tv the qled logo is blinking turn on and off the tv I tried to tape the t con cable and I found the right pin for the tv is stable turned on but no picture, no qled picture only back light and not arrive the currrent for the t con board 3,3v ok, 1,8v ok and other litle currents but the maybe Vcom current is not arrive. (12v?) when the qled logo is blink I measure this point 6,9-7V.
  • Answer selected by Dave03 at 02-06-2024, 03:37 AM.
    William1967
    • Nov 2017
    • 215
    • Netherlands
    This TV does not have a separate T-con, it is built into the mainboard. Does the standby LED flash when you turn on the TV? If so how often?
    • William1967
      • Nov 2017
      • 215
      • Netherlands
      • Dave03
        • 4
        • Magyarország
        The standby led is turn on when the tv is turning on the tv is turned on the standby led is turn off. The tv is turn off and aggain turning on the standby led is triggering and the tv is turn on the standby led is turn off.
        • Storyteller12
          • Jun 2020
          • 625
          Sounds like a panel issue. Possibly the diode pack on the buffer board.
          • Dave03
            • 4
            • Magyarország
            The standby led I want to attach video from my standby led it s so difficult to write down hows blinking how I can attach video?
            • Dave03
              • 4
              • Magyarország
              I found 1 problem in the vss test point measured the good tv this point in diode mode OL but the bad tv I measured 1,05V opening voltage I measure this point the resistance the bad one is 1k the good one is 0 and the good tv in working make -4,21V this vss point and the bad is 0V the problem was the vss line.
                Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                09-07-2024, 12:10 AM
                09-07-2024, 05:50 AM
              • howardc64
                Samsung UN55JU650DF network/streaming problem
                by howardc64
                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                07-09-2025, 12:44 PM
              • alro7779
                Samsung UN55MU6103F video problem; has colored stripes on the display
                by alro7779
                Hello, everyone!
                A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                09-27-2025, 11:29 PM
              • Kaar3l
                Samsung QLED QE65Q7FNAT only standby light
                by Kaar3l
                TV: Samsung QLED QE65Q7FNAT
                PSU: BN4400940A
                MB: BN94-12832K
                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                09-24-2024, 01:35 PM
