No Vs output. Bad power supply and no sign of damage anywhere. Board model eay4050440. Any place to start test?
LG 32LG3000 No Power (eay4050440)
Re: LG 32LG3000 No Power (eay4050440)
Post good clear pictures of boards and close ups of connectors
tell us what happens when you
1. Plug it in
2. Switch it on
Any lights sounds whistles flashes smells. what does power led do.
Test any fuses you can find .
Test for voltages on connector to main board. Meter on vDC use ground screw for negative test and report voltage on each pin.Please upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostPost good clear pictures of boards and close ups of connectors
1. Plug it in
2. Switch it on
No great camera available at the moment so no great pictures to show. No sounds. Power led flashes then goes out; nothing else. Im not getting the 24v output to the inverter.Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
Could be tcon or main- check the connectors main-tcon-panel. Look for little fuses or
0 rated resistors near the connectorsPlease upload pictures using attachment function when ask for help on the repair
