L.G. 42PC1D, dark flickering pic.
  • adamp91gvm
    • Jan 2014
    • 706
    #41
    Re: L.G. 42PC1D, dark flickering pic.
    It's in work and I'm off for 2 weeks on jury service :s
    • adamp91gvm
      • Jan 2014
      • 706
      #42
      I'm getting 8.89v max the the t con I thought it should be more than that correct me if I'm wrong
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        #43
        The 'CONTROL-BOARD' (T-Con is LCD!) should have 5V, not 8.8V to it.....
        Check at the vacant socket marked, '5V'
        TELEFIX
        • adamp91gvm
          • Jan 2014
          • 706
          #44
          Lol u know what I mean well it says 15v on part of the control board
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            #45
            Err--15V --on the socket marked 5v...?
            TELEFIX
            • adamp91gvm
              • Jan 2014
              • 706
              #46
              Just therr where the ribbon comes in
                Using AC or DC mode? You should use DC mode. Also check multimeter battery, low battery can cause bad readings.
                • adamp91gvm
                  • Jan 2014
                  • 706
                  #48
                  Dc mode checked the volts on a new battery and there correct
                    What you getting (volts mode) each end of device FL11 next to that connector?
                    • adamp91gvm
                      • Jan 2014
                      • 706
                      #50
                      4.85v
                        What about across C13?
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          #52
                          Originally posted by adamp91gvm
                          4.85v
                          Ah--Thats more like it!
                          Dunno what you were measuring before!
                          So--with Everything connected--what happens when you pull the Vs fuse on the Y-SUS board and switch on?
                          Same with Y-SUS fuse back in and Z-SUS Vs fuse removed
                          TELEFIX
                          • adamp91gvm
                            • Jan 2014
                            • 706
                            #53
                            8.83v one side and 0v closest to the edge of board
                              Looks like your 15V is low, that will cause problems. Can you see where 15V might be generated on PSU? Any 15V output on the pins?
                              Come to think of it - having only done one of these sets over 2 years ago - I believe the 15V could be generated by the Y-sustain board from the 5V input.
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                #55
                                Yup--The 15V (two of them) plus an additional 5V rail are made on the Y-SUS from the 5V rail.
                                --Prob a faulty IPM dragging it down.
                                TELEFIX
                                • adamp91gvm
                                  • Jan 2014
                                  • 706
                                  #56
                                  Here ?
                                  • Alastair E
                                    Chief Womble
                                    • Mar 2013
                                    • 1963
                                    • U.K.
                                    #57
                                    Yup--But!
                                    These supplies ground--isnt ground, they are referenced to other supplies.
                                    You'll have to use the IC Tab as the ground when testing the voltage.
                                    --Suggest you remove board and supply it with 5V, Then test the supplies--for safety reasons.
                                    TELEFIX
                                      That's 15V relative to -Vy, if -Vy is around -190V it should measure about -175V (-190V + 15V)
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        #59
                                        Dont think there's gonna be any -Vy, as the PSU shuts down.....
                                        These 15V supplies are pretty critical to the operation of the IPM's--they form the supplies to the high and low-side drivers, and if low will kill an IPM, due to poor/soft switching, and excess dissipation....
                                        No matter what--Replace all the caps around those three regs the 33uF caps, --use 47uF 50V the 68uF, use 100uF 50V, (both Rubycon ZL are recommended, just use a fair to good quality wire-ended, not SM types to replace) and don't forget the 330uF big one near the board edge--470uF is good for that these values I fitted to mine.
                                        --The 15V regs should easily supply a 5W 12V lamp to full brightness and full 15V--although do not test like this with board connected to set--ONLY by 5V from a separate PSU, board out of set.
                                        Still say the dead IPM is dragging down the 15V rail, leaving only 8V.
                                        TELEFIX
                                          Actually the 15V(-Vy) is for the PASS FETs and buffer board. Buffer board logic is run from 5V linear reg off the 15V(-Vy). IPM 15V is relative to normal chassis ground.
                                          Low -Vy would generally point to a bad buffer board though it's possible for an IPM to cause this fault too if the SUS or ERC node is shorted.
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
                                          • reessi
                                            ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                            by reessi
                                            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                            They are black on the right and gradually fade to nothing on the far left.
                                            They start either after 5 mins or up to 2 hours after so annoying for testing.
                                            They flicker continuously very fast! With a slight pause milli-second every second.
                                            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                            I tested each half by removing the first the left flex from...
                                            06-03-2025, 09:58 AM
                                          • bo_vest
                                            LG 42PC1D (PDP42X30401) wiht flickering image and Vzb high
                                            by bo_vest
                                            Hello. I wonder if any of you guys may be able to point me in the right direction here.
                                            My 42PC1D (PDP42X30401) always had some red dots on black background. It never bothered me too much. One day it died (switched off)
                                            I replaced the Y-SUS board and it worked for a few days. After a few days I started getting grainy image when the set was cold. As soon as it warmed up it worked. The graining got worse and worse until it stopped working. Now I get flickering white dots. I can just about make out the menu on the screen so I know the TV as such is working because the menu...
                                            04-06-2021, 09:47 AM
                                          • DrvLikHell
                                            Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                            by DrvLikHell
                                            Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                            The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                            07-05-2024, 02:54 AM
                                          • Lintesir
                                            Panasonic P42S30 Plasma - Pink sparkles
                                            by Lintesir
                                            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
                                            There is about a 5cm high region at the top without any sparkles,...
                                            07-26-2024, 03:16 AM
