Repair a QLED tv. Same process as a normal led TV?
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi! I'm tempted to purchase a "broken, as is" Samsung 50q60t tv on sale.
    Seller states "we were watching TV and it went to black with only audio, then it went into constant reboot mode"
    Maybe only a led strip replacement is enough but I need to take the risk.
    From the little information I've been able to find, looks like these QLED tvs are different inside:
    • Are led strips available online and at reasonable prices too?
    • Is disassembly the same procedure as led TV? I've managed to swap led strips up to 50" with no issues on normal led tvs
    • Any special tool required? I've seen videos of people using heat gun and other stuff...
    Thanks in advance!!
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    QLED is marketing garbage by samsung, it's an LCD, some have blue LED backlight with some yellow filter, but that's it, they may have the screen glued to the bezel which would make backlight repair very "fun".
    Reboot seems like screen fault, common for T 2020/ A 2021 series.
    • edugimeno
      • May 2017
      • 581
      • Spain
      Thanks Biruslapio, after posting this question I found some other posts and videos and it looks like my chances are:
      -D001 or D002 ESD protection diode block, can be removed safely as many reported
      -Internal short in LCD, which seems to be "repairable" with the masking method, assuming some quality loss
      I haven't disassembled this TV yet.
      Thanks!
      • EazyBone
        • Jun 2023
        • 1347
        • United states
        Don't buy it. Reboot for Samsung means a panel problem or the line to panel. Basically it's effed. Rare chances people have fixed them. Stay away
        Reboot is not backlights it's panel. And yes repair of lights on these tvs are a nightmare. If even that was true. I took several apart just for parts and it was impossible without breaking something. It can be done id say but not worth the time. Again it ain't the backlight if it's rebooting it's the panel
        • edugimeno
          • May 2017
          • 581
          • Spain
          Too late, it's already on my desk LOL
          I will probably take a look at it next weekend
          • nomoresonys
            • 12206
            • U.S.
            Suppose it could be a firmware issue.
            • edugimeno
              • May 2017
              • 581
              • Spain
              Ok after watching dozens of videos of people with the exact same TV and same problem and being able to fix them with the LVDS cable taping methid, I went to my town home where I have this TV.
              I disassembled it (a little hard if you don't know, they don't have screws and the plessure tabs are very firm)
              Tried with the main board socket disconnected. All backlight went on full brightness, no reboots. So PS is good
              Plug main to PS again and unplugged LVDS output from main. TV went on, full BL at first, then dimmed light, and stable, of course no image but it woudn't reboot
              Than I reconnected LVDS and took out the flex that joins left to right side of panel. Nothing changed, so the issue must be on the right side of the panel (the one where the LVDS directly plugs in, the left one uses the intermediate flex)
              So I started the tape "method" in the main LVDS cable. It didn't affect at all when taping the left half pins, seems that those are driven to the left side panel which is good
              Then I started taping the right side of LVDS with different widths of tape and at different positions. I spent over an hour moving tape left and right, and using half, double...all sizes. I was able to see a litttle of everything:
              • Nothing at all, but would boot
              • single discontinous line
              • some random horizontal lines
              • some random horizontal and vertical lines, very erratic
              After all this time I wansn't able to get anything close to a recognisable image. Should I keep trying? Should I give up assuming the panel is too damaged?
              Thanks!​
              • Instafixx
                Macbook A2179 820-01958
                by Instafixx
                Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                I checked the Power Sequences below and found this -
                Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                05-20-2023, 05:19 AM
                Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                09-07-2024, 12:10 AM
              • Kingfreddie
                LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                by Kingfreddie
                Ok.. this is the story:
                Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                This is kinda how it looked, just that mine were at the bottom of the screen:
                09-11-2021, 01:57 AM
              • Takeatry
                Yet another Samsung QLED Boot Loop
                by Takeatry
                Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                10-04-2024, 02:57 PM
              • cook
                HP Power Supply 6632A: Fast Mode vs Normal Mode?
                by cook
                FAST MODE vs NORMAL MODE
                I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                06-07-2020, 05:32 AM
