Vizio DPS-167DP-1 failure
    • 12206
    • U.S.
    If that cap isn't doing anything it might be bad, do you have a spare to try.
    • Nr4ps
      • Dec 2023
      • 18
      Original was 10uF 50V. I replaced with 0.47uF 50V (closest I had). Still doesn't charge. I think I'm going to have to figure out more about how this thing is supposed to work. 120 VAC comes in and gets converted to 170 VDC at BD1, labeled in photo. Right now, pins 2 and 3 of T901 sit at 170VDC relative to that same negative post. I guess an AC component is supposed to ride on top of that to energize the transformer, but I'm not getting any.
      • lotas
        • Jan 2016
        • 4651
        • Russia
        0.47 µF 50 V is very small, set 10, 22, 33, 47 µF 50 V.
        • Nr4ps
          • Dec 2023
          • 18
          I tried 100 uF 100V and still nothing.
            • 12206
            • U.S.
            So grab a 10 to 50 uf 50 volt cap and put in there, you can find them in a lot of old junk non-working electronics if you don't have one at hand, grab the datasheet for IC901 and post it here.
              • 12206
              • U.S.
              #26
              Be sure to check ZD909 and D950B, ZD 909 will need to be checked out of circuit, maybe also check C910, check R915, also check R907 A and B on bottom of board by IC901, R907 A and B should probably be about 2 ohms.
              • Nr4ps
                • Dec 2023
                • 18
                ZD909 and D950B were two of the components that were originally blown and I had to replace. Replacements were tested out of circuit. I also measured R907 A and B at about 2 ohms in circuit.
                IC901 datasheet attached.
                I'll get back to you on C910 and trying to find a closer replacement for C904B.
                • Nr4ps
                  • Dec 2023
                  • 18
                  C910 measures 64 uF in-circuit. I imagine that means there's another capacitance in parallel with it somewhere and that's not all due to that tiny ceramic cap. But it's not shorted. Is that good enough or shall I desolder it?
                  R915 is also one of the components I originally replaced. It measures 4.7 ohms.
                  For C904B I found a 15uF 200V capacitor that I put in, and it still doesn't charge. This is with IC901 installed again. (Original measures good at 10.5 uF out of circuit, by the way.)
                  Thanks for your ongoing suggestions. I'm a little impressed you haven't given up on me yet.
                    • 12206
                    • U.S.
                    #29
                    Guess I don't know, I have run across a situation where one of the zener diodes was leaking and you couldn't tell by testing with multimeter, maybe replace those? I don't think I would go with 200 volts on that replacement cap, that seems like quite a stretch from 50 but DO NOT go below 50, maybe recheck your work, many time a solder will look good but not be. I can't even remember how these things work, bad memory. I'll brush up on it if I get time.
                      • 12206
                      • U.S.
                      #30
                      There's the ebay page, most kits show the same parts, there's a board there for 50 bucks: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
                        • 12206
                        • U.S.
                        #31
                        Check the description on this kit, might give an extra clue: https://www.ebay.com/itm/11448308479...sAAOSwlc1fllAn
                          • 12206
                          • U.S.
                          #32
                          Another thing to check is CN202 connector, make sure all the solders are good.
                          • Nr4ps
                            • Dec 2023
                            • 18
                            The kit on ebay includes the same four parts that I already replaced. I've been looking for a bad solder joint but not finding anything. Everything I resoldered has continuity to where it seems like it should. CN202 looks fine, and I think that connector is just for getting power to the backlight anyway. Wish I understood more how this thing was supposed to work. I was hoping to avoid buying a whole new board, but maybe I'm just being stubborn at this point.
                            • Nr4ps
                              • Dec 2023
                              • 18
                              I don't know if this addresses that thought correctly, but to a quick test in reverse bias the four zeners in that cluster that I didn't replace seem to break down at about the right voltage:
                              Zd900 6.1V (labeled 6V2)
                              Zd902 12.7V (labeled 13B)
                              Zd904 15.9v (labeled 16B)
                              Zd907 24V (labeled 24B)
                              • linksys1127
                                • Sep 2016
                                • 121
                                I’m struggling with this board as well. Initially I had the same defective parts. Replaced them and still nothing. I have scoured my board to find the defect. I’ve found nothing out of range. It’s a real head scratcher! The only thing I can think of is a defective LD7913. Did you get yours working? What did you find?
                                • Nr4ps
                                  • Dec 2023
                                  • 18
                                  I never figured this out. I don't think it can be the replacement LD7913 that I installed because, according to the datasheet that chip doesn't even turn on until the brownout protection pin is above a certain voltage - and the capacitor on that pin won't charge.
                                  • linksys1127
                                    • Sep 2016
                                    • 121
                                    Thank you for the data sheet you provided! When I get a chance to return to this project I’ll update what I find. Right now I feel like I’m chasing my tail on it! Keeps leading me back to the PWM IC being faulty. When I ordered them they came in a pack of five. I replaced it with another. Same result! Need to walk away for a bit for a fresh prospective! Have other projects that need attention. Thanks again for your update!
                                    • howardc64
                                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                      by howardc64
                                      Problem
                                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                      Model & Board Pics
                                      Conflicting Spec
                                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                      https://www.shopjimmy.com/vizio-gj-2k1...
                                      10-10-2024, 01:16 PM
                                    • SS454
                                      vizio e650i-a2 backlight flashes then turns off
                                      by SS454
                                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                      panel: au optronics T650HVN05.4
                                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                      08-20-2020, 03:57 PM
                                    • mrtek
                                      Vizio M65-C1
                                      by mrtek
                                      Hi.
                                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                      07-14-2025, 07:28 PM
                                    • howardc64
                                      Vizio SmartCast TV software bug that looks like hardware
                                      by howardc64
                                      Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                      It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                      11-16-2024, 05:17 PM
