Samsung UN55B7100WF Bad Panel/T-CON?
  • ipaduser123
    • Jan 2014
    I have a samsung tv that has a problem similar to what is in this youtube video: http://www.youtube.com/watch?v=2zD3NdfxihM
    Does this look like a T-CON issue, or is it a bad panel, or something else? I hope it is a T-CON issue.
    Thanks!
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: Samsung UN55B7100WF Bad Panel/T-CON?
    if you bring up the menu,does the lines run through it also?if it does,more likely panel fail,tab bonds
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • NWArkGuy
      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
      by NWArkGuy
      Well, I will be the first to admit that I screwed up...
      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
      I have 2 that I have found and have in my possession. ...
      10-12-2023, 10:13 PM
    • Kjell
      Samsung Series 9 - BIOS issue
      by Kjell
      After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
      Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
      08-01-2025, 09:15 AM
      09-07-2024, 05:50 AM
    • netgearnetgear
      TCL 43S423 TCON OR PANEL FAULTY???
      by netgearnetgear
      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
      08-20-2025, 06:04 PM
